Does anyone know of a device that can strip HDCP 2.0 from an HDMI source and output it to HDMI?
I have a scenario where I need to take 4k output content and remove HDCP from it and fed it to a capture card.
Okay, before you type, I want to assure you that there is no nefarious objectives with this…seriously this is for my work. I need to test the output of set to boxes but the HDCP protection makes it difficult.
While this doesn’t solve the problem, I could use it in a chain to convert HDCP 2.2 to 1.4 and then use a common chinese HDMI spliter to remove the 1.4. and hook up the spliter to the capture card.
