Who is liking the new colors in the logo?
I donāt mind it.
Itās a nice change, fits with the color scheme and not completely obnoxious, so Iām all for it.
Just ran across this on Superuser. Thought it was relevant.
I donāt think I could ever do this challengeā¦ when I sit to program, before I know it 6+ hours are goneā¦ working in 1 hr increments would be torture.
I didnāt see any time limit
the rules say
Whole December. Every day. At least 1 hour a day.
Looks like it needs a regex: h(im|er)self
I am in. Going to write the Longest Hello World program in the world
Lazy programming, not counting for edge cases.
Fix this, commit it and Iāll consider merging it at that point.
Alright, Iām awake from my nap! Time to get to work!
Did you just assume my variable type?
I believe its to keep one dedicated, and focused on the problem.
Oh, so this is why static typing has fallen out of favour. Now I see how it is.
luke@mercury ~/code/src/gitlab.com/devember2017 $ git push heroku master
Counting objects: 26, done.
Delta compression using up to 4 threads.
Compressing objects: 100% (22/22), done.
Writing objects: 100% (26/26), 26.60 KiB | 5.32 MiB/s, done.
Total 26 (delta 2), reused 2 (delta 0)
remote: Compressing source files... done.
remote: Building source:
remote:
remote: -----> Node.js app detected
remote:
remote: -----> Creating runtime environment
remote:
remote: NPM_CONFIG_LOGLEVEL=error
remote: NPM_CONFIG_PRODUCTION=true
remote: NODE_VERBOSE=false
remote: NODE_ENV=production
remote: NODE_MODULES_CACHE=true
remote:
remote: -----> Installing binaries
remote: engines.node (package.json): 8.9.1
remote: engines.npm (package.json): unspecified (use default)
remote:
remote: Resolving node version 8.9.1...
remote: Downloading and installing node 8.9.1...
remote: Using default npm version: 5.5.1
remote:
remote: -----> Restoring cache
remote: Skipping cache restore (not-found)
remote:
remote: -----> Building dependencies
remote: Installing node modules (package.json + package-lock)
remote: added 49 packages in 2.735s
remote:
remote: -----> Caching build
remote: Clearing previous node cache
remote: Saving 2 cacheDirectories (default):
remote: - node_modules
remote: - bower_components (nothing to cache)
remote:
remote: -----> Build succeeded!
remote: -----> Discovering process types
remote: Procfile declares types -> web
remote:
remote: -----> Compressing...
remote: Done: 17.8M
remote: -----> Launching...
remote: Released v3
remote: https://fast-gorge-78145.herokuapp.com/ deployed to Heroku
remote:
remote: Verifying deploy... done.
To https://git.heroku.com/fast-gorge-78145.git
* [new branch] master -> master
Dang it! Why did you have to post this!!!
Iām so burnt out from work, but really want to do some āmeā programming rather than ācan you program this for meā programming.
Iāve done my hour for the day, so Iām in the clear, but Iāll have to consider itā¦
Iāll probably do some super boring āback to the basicsā programming and not anything sexy.
Like writing a LRU cache in C, or emplementing an AVL tree in Ruby. Weāre talking an algos and data structure refresher here
Sheeze, I really miss āfun/meaningfulā programming.
Try x86 Assembly
@cotton Here is a hello world example I did to help get you started.
~> nasm -f elf source.asm
~> ld -m elf_i386 -s -o executable source.o
~> ./executable
Thatās for sure a goal. Hopefully, that will lead to reverse engineering, but I donāt have the willpower to push through that. Lol!
Iām just going back to boring basics.
Boo!
I really need to brush up on my pointers and data structures. You never know when you may need a solid fifo queue in C++
Come on, do it! Thereās still time left in the day.
