The Smart home system I use has a terrible user interface. The time frames for graphs are locked, there’s no way to export data and you can’t turn on a light for a certain period of time, only at a preset time.
The goal is to create a better UI using the Energenie API and Unity. If that goes well a remote web portal using Linode will be attempted.
All I know so far is Energenie has an API…
