Ok, so I just installed Deus Ex Invisible War on my laptop, and the native resolution of the laptop is 1440x900, but in the Deus Ex settings I can only adjust it to 1024x768, does anyone know why this could be? (in Deus Ex 1 I can set it to 1440x900 easily).
Well usually with older games you cant increase resolution
But there is a trick you can try, worked with bf2 were it capped me off at the same resolution.
right click your shortcut and add this at the end of your target "+menu 1 +fullscreen 1 +szx 1400 +szy 900"
note this most likely won't work and if it does it will only stretch your screenÂ
you can also try this as well
http://www.john-p.com/textures/DX-IW/index.shtml
this a highres texture pack which may or may not increase res, but will make your game look better
I don't think that worked, but thanks for trying anyway
- I already had the highres texture packs, didn't seem to effect the resolution :s
This game was always "jittery" for me for some reason. It just didn't play smoothly.
Yeah, I've played about 5 mins (just to test it's working) and it does seem a little jittery.
love that game!!!
Thanks Onizucca - I'll give it a try now and report back.
That worked like a treat, thanking you Onizucca heart
I have lots of games (and anime :P) installed and ready to be played on my laptop now (I'm going into a deadzone for 2 weeks on 26th Oh noes!).
No problem, clad I could help.
So I've played it for about an hour, seems pretty good, there's only one flaw so far, and it's pretty major - there's thousands of load screens, becomes annoying, as well as the Vista-like UAC "Are you sure you want to go to x?".
