Got blocked for some hours, I copy pasted the last logs I could pull out of Linux Mint. Does it help?
I doubt it since the issue happen in no other OS except Linux, maybe not in non-Ubuntu based ones. Not to mention someone else over at LTT with almost same CPU and same chipset(other board model) had exact same issueā¦ (his solution was to stick to 14.04 until he replaced it all with Ryzen.)
What is Solaris based on?
Lol.
I think itās derived from BSD. You donāt want to use it, and not for that reason.
Have you considered getting a pcie usb card with a modern usb chipset?
Does USB on your case have usb2 or usb3 headers?
I got a ASRock PCI-E card actually, that also stops to function if I remember rightā¦ (I could try it again tough maybe I will get lucky?)
BSD is that terrible? :S
No, but Oracle and Solaris is.
Use a library card system before using that piece of garbage.
Is this usable info?
Nov 25 19:56:41 ntpd: Soliciting pool server 2a02:a18:7510:200::
Nov 25 19:56:22 dbus-daemon: [system] Reloaded configuration
Nov 25 19:56:22 systemd: Reloading.
Nov 25 19:56:20 wpa_supplicant: wlp7s6: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-46 noise=-86 txrate=270000
Nov 25 19:56:20 systemd: Started LSB: automatic crash report generation.
Nov 25 19:56:20 apport: ā¦done.
Nov 25 19:56:20 systemd: Starting LSB: automatic crash report generationā¦
Nov 25 19:56:17 dbus-send: method return time=1543172177.309625 sender=org.freedesktop.DBus -> destination=:1.82 serial=3 reply_serial=2
Nov 25 19:56:17 dbus-daemon: [system] Reloaded configuration
Nov 25 19:56:17 systemd: Reloading D-Bus System Message Bus.
Nov 25 19:56:16 dbus-daemon: [system] Reloaded configuration
Nov 25 19:56:16 systemd: Reloading.
Nov 25 19:56:16 udisksd: Acquired the name org.freedesktop.UDisks2 on the system message bus
Nov 25 19:56:16 systemd: Started Disk Manager.
Nov 25 19:56:15 udisksd: Failed to load the āmdraidā libblockdev plugin
Nov 25 19:56:15 systemd: Starting Disk Managerā¦
Nov 25 19:56:15 udisksd: udisks daemon version 2.7.6 exiting
Nov 25 19:56:15 systemd: Stopping Disk Managerā¦
Nov 25 19:56:15 dbus-daemon: [system] Reloaded configuration
Nov 25 19:56:14 systemd: Reloading.
Nov 25 19:56:11 packagekitd: daemon quit
Nov 25 19:56:11 systemd: Reloaded D-Bus System Message Bus.
Nov 25 19:56:11 dbus-send: method return time=1543172171.166429 sender=org.freedesktop.DBus -> destination=:1.79 serial=3 reply_serial=2
Nov 25 19:56:11 dbus-daemon: [system] Reloaded configuration
Nov 25 19:56:11 systemd: Reloading D-Bus System Message Bus.
Nov 25 19:56:10 dbus-daemon: [system] Reloaded configuration
Nov 25 19:56:10 systemd: Started Dispatcher daemon for systemd-networkd.
Nov 25 19:56:10 networkd-dispat: WARNING: systemd-networkd is not running, output will be incomplete.
Nov 25 19:56:10 systemd: Starting Dispatcher daemon for systemd-networkdā¦
Nov 25 19:55:48 dbus-send: method return time=1543172148.343512 sender=org.freedesktop.DBus -> destination=:1.77 serial=3 reply_serial=2
Nov 25 19:55:48 dbus-daemon: [system] Reloaded configuration
Nov 25 19:55:48 systemd: Reloading D-Bus System Message Bus.
Nov 25 19:55:46 systemd: Reloading.
Nov 25 19:55:45 dbus-daemon: [system] Reloaded configuration
Nov 25 19:55:45 systemd: Reloading.
Nov 25 19:55:44 kernel: debug: running subtest /usr/lib/os-probes/mounted/efi
Nov 25 19:55:41 kernel: QNX4 filesystem 0.2.3 registered.
Nov 25 19:55:41 kernel: ntfs: driver 2.1.32 [Flags: R/O MODULE].
Nov 25 19:55:41 kernel: JFS: nTxBlock = 8192, nTxLock = 65536
Nov 25 19:55:41 kernel: SGI XFS with ACLs, security attributes, realtime, no debug enabled
Nov 25 19:55:40 avahi-daemon: No service file found in /etc/avahi/services.
Nov 25 19:55:38 kernel: audit: type=1400 audit(1543172138.518:52): apparmor=āSTATUSā operation=āprofile_replaceā info=āsame as current profile, skippingā profile=āunconfinedā name=āman_groffā pid=21714 comm=āapparmor_parserā
Nov 25 19:55:38 kernel: kauditd_printk_skb: 16 callbacks suppressed
Nov 25 19:55:38 apparmor_parser: AVC apparmor=āSTATUSā operation=āprofile_replaceā info=āsame as current profile, skippingā profile=āunconfinedā name=āman_groffā pid=21714 comm=āapparmor_parserā
Nov 25 19:55:38 ntpd: receive: Unexpected origin timestamp 0xdfa56ea3.829a215b does not match aorg 0000000000.00000000 from [email protected] xmt 0xdfa56eaa.7015fb57
Nov 25 19:55:25 NetworkManager: [1543172125.0475] supplicant: wpa_supplicant die count reset
Nov 25 19:55:24 systemd: Reloading.
Nov 25 19:55:24 grub-common: ā¦done.
Nov 25 19:55:24 systemd: Starting LSB: Record successful boot for GRUBā¦
Nov 25 19:55:24 ntpd: Soliciting pool server 77.95.77.250
Nov 25 20:58:41 systemd-journal: Time spent on flushing to /var is 7.727ms for 977 entries.
Nov 25 20:58:41 systemd: Started udev Kernel Device Manager.
Nov 25 20:58:41 keyboard-setup.: cannot open file /tmp/tmpkbd.S96gRp
Nov 25 20:58:41 kernel: Inserted module āparport_pcā
Nov 25 20:58:41 systemd-journal: Runtime journal (/run/log/journal/0be4b885ddb347e5bc70559303dca99f) is 8.0M, max 160.4M, 152.4M free.
Nov 25 20:58:41 kernel: ppdev: user-space parallel port driver
Nov 25 20:58:41 kernel: lp: driver loaded but no devices found
Nov 25 20:58:41 kernel: EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
Nov 25 20:58:41 kernel: Listening on /dev/initctl Compatibility Named Pipe.
Nov 25 20:58:41 kernel: Created slice System Slice.
Nov 25 20:58:41 kernel: Reached target System Time Synchronized.
Nov 25 20:58:41 kernel: Set up automount Arbitrary Executable File Formats File System Automount Point.
Nov 25 20:58:41 kernel: Started Forward Password Requests to Wall Directory Watch.
Nov 25 20:58:41 kernel: Set hostname to .
Nov 25 20:58:41 kernel: Detected architecture x86-64.
Nov 25 20:58:41 kernel: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
Nov 25 20:58:41 kernel: ip_tables: Ā© 2000-2006 Netfilter Core Team
Nov 25 20:58:41 kernel: EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
Nov 25 20:58:41 kernel: clocksource: Switched to clocksource tsc
Nov 25 20:58:41 kernel: Btrfs loaded, crc32c=crc32c-intel
Nov 25 20:58:41 kernel: xor: automatically using best checksumming function avx
Nov 25 20:58:41 kernel: raid6: using ssse3x2 recovery algorithm
Nov 25 20:58:41 kernel: [drm] {1920x1080, 2200x1125@148500Khz}
Nov 25 20:58:41 kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x420bee34340, max_idle_ns: 440795428783 ns
Nov 25 20:58:41 kernel: tsc: Refined TSC clocksource calibration: 4581.982 MHz
Nov 25 20:58:41 kernel: [drm] Initialized amdgpu 3.23.0 20150101 for 0000:03:00.0 on minor 0
Nov 25 20:58:41 kernel: amdgpu 0000:03:00.0: kfd not supported on this ASIC
Nov 25 20:58:41 kernel: Console: switching to colour frame buffer device 240x67
Nov 25 20:58:41 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Nov 25 20:58:41 kernel: [drm] pitch is 7680
Nov 25 20:58:41 kernel: sd 3:0:0:0: [sdd] Attached SCSI disk
Nov 25 20:58:41 kernel: sdd: sdd1 sdd2
Nov 25 20:58:41 kernel: sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 20:58:41 kernel: scsi 3:0:0:0: Direct-Access ATA ST2000DX001-1NS1 CC41 PQ: 0 ANSI: 5
Nov 25 20:58:41 kernel: ata4.00: configured for UDMA/133
Nov 25 20:58:41 kernel: [drm] UVD and UVD ENC initialized successfully.
Nov 25 20:58:41 kernel: sd 2:0:0:0: [sdc] Attached SCSI disk
Nov 25 20:58:41 kernel: sdc: sdc1
Nov 25 20:58:41 kernel: [drm] ring test on 11 succeeded in 11 usecs
Nov 25 20:58:41 kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Nov 25 20:58:41 kernel: sdb: sdb1 sdb2 sdb3 sdb4 sdb5
Nov 25 20:58:41 kernel: sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 20:58:41 kernel: scsi 2:0:0:0: Direct-Access ATA ST2000DM001-1ER1 CC25 PQ: 0 ANSI: 5
Nov 25 20:58:41 kernel: sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Nov 25 20:58:41 kernel: scsi 1:0:0:0: Direct-Access ATA Samsung SSD 850 1B6Q PQ: 0 ANSI: 5
Nov 25 20:58:41 kernel: ata2.00: configured for UDMA/133
Nov 25 20:58:41 kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 20:58:41 kernel: scsi 0:0:0:0: Direct-Access ATA Samsung SSD 850 1B6Q PQ: 0 ANSI: 5
Nov 25 20:58:41 kernel: ata2.00: NCQ Send/Recv Log not supported
Nov 25 20:58:41 kernel: ata1.00: configured for UDMA/133
Nov 25 20:58:41 kernel: ata2.00: supports DRM functions and may not be fully accessible
Nov 25 21:12:52 systemd-journal: Time spent on flushing to /var is 6.525ms for 974 entries.
Nov 25 21:12:52 systemd: Starting Flush Journal to Persistent Storageā¦
Nov 25 21:12:52 keyboard-setup.: cannot open file /tmp/tmpkbd.S96gRp
Nov 25 21:12:52 systemd-modules: Inserted module āppdevā
Nov 25 21:12:52 systemd-journal: Runtime journal (/run/log/journal/0be4b885ddb347e5bc70559303dca99f) is 8.0M, max 160.4M, 152.4M free.
Nov 25 21:12:52 kernel: EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
Nov 25 21:12:52 kernel: parport0: irq 0 detected
Nov 25 21:12:52 kernel: ppdev: user-space parallel port driver
Nov 25 21:12:52 kernel: lp: driver loaded but no devices found
Nov 25 21:12:52 kernel: Starting Load Kernel Modulesā¦
Nov 25 21:12:52 kernel: Listening on Journal Socket.
Nov 25 21:12:52 kernel: Created slice System Slice.
Nov 25 21:12:52 kernel: Reached target Remote File Systems.
Nov 25 21:12:52 kernel: Started Forward Password Requests to Wall Directory Watch.
Nov 25 21:12:52 kernel: Created slice User and Session Slice.
Nov 25 21:12:52 kernel: Set hostname to .
Nov 25 21:12:52 kernel: Detected architecture x86-64.
Nov 25 21:12:52 kernel: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
Nov 25 21:12:52 kernel: ip_tables: Ā© 2000-2006 Netfilter Core Team
Nov 25 21:12:52 kernel: EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
Nov 25 21:12:52 kernel: Btrfs loaded, crc32c=crc32c-intel
Nov 25 21:12:52 kernel: xor: automatically using best checksumming function avx
Nov 25 21:12:52 kernel: raid6: using ssse3x2 recovery algorithm
Nov 25 21:12:52 kernel: [drm] {1920x1080, 2200x1125@148500Khz}
Nov 25 21:12:52 kernel: clocksource: Switched to clocksource tsc
Nov 25 21:12:52 kernel: tsc: Refined TSC clocksource calibration: 4581.983 MHz
Nov 25 21:12:52 kernel: [drm] Initialized amdgpu 3.23.0 20150101 for 0000:03:00.0 on minor 0
Nov 25 21:12:52 kernel: amdgpu 0000:03:00.0: kfd not supported on this ASIC
Nov 25 21:12:52 kernel: Console: switching to colour frame buffer device 240x67
Nov 25 21:12:52 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Nov 25 21:12:52 kernel: [drm] pitch is 7680
Nov 25 21:12:52 kernel: sd 3:0:0:0: [sdd] Attached SCSI disk
Nov 25 21:12:52 kernel: sdd: sdd1 sdd2
Nov 25 21:12:52 kernel: sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 21:12:52 kernel: scsi 3:0:0:0: Direct-Access ATA ST2000DX001-1NS1 CC41 PQ: 0 ANSI: 5
Nov 25 21:12:52 kernel: ata4.00: configured for UDMA/133
Nov 25 21:12:52 kernel: sd 2:0:0:0: [sdc] Attached SCSI disk
Nov 25 21:12:52 kernel: sdc: sdc1
Nov 25 21:12:52 kernel: ata4.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
Nov 25 21:12:52 kernel: [drm] UVD and UVD ENC initialized successfully.
Nov 25 21:12:52 kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Nov 25 21:12:52 kernel: sdb: sdb1 sdb2 sdb3 sdb4 sdb5
Nov 25 21:12:52 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Nov 25 21:12:52 kernel: sda: sda1 sda2
Nov 25 21:12:52 kernel: sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 21:12:52 kernel: scsi 2:0:0:0: Direct-Access ATA ST2000DM001-1ER1 CC25 PQ: 0 ANSI: 5
Nov 25 21:12:52 kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 21:12:52 kernel: scsi 1:0:0:0: Direct-Access ATA Samsung SSD 850 1B6Q PQ: 0 ANSI: 5
Nov 25 21:12:52 kernel: ata2.00: configured for UDMA/133
Nov 25 21:12:52 kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 21:12:52 kernel: ata2.00: NCQ Send/Recv Log not supported
19:58:41 systemd: Started Hostname Service.
19:58:41 dbus-daemon: [system] Successfully activated service āorg.freedesktop.hostname1ā
19:58:41 systemd: Starting Hostname Serviceā¦
19:58:41 dbus-daemon: [system] Activating via systemd: service name=āorg.freedesktop.hostname1ā unit=ādbus-org.freedesktop.hostname1.serviceā requested by ā:1.79ā (uid=1000 pid=2578 comm="gnome-logs " label=āunconfinedā)
19:56:54 anacron: Job cron.dailyā terminated 19:56:52 rsyslogd: [origin software=ārsyslogdā swVersion=ā8.32.0ā x-pid=ā929ā x-info=āhttp://www.rsyslog.comā] rsyslogd was HUPed 19:56:52 systemd: Started Make remote CUPS printers available locally. 19:56:51 logger: no dictionary update necessary. 19:56:51 anacron: Updated timestamp for jobcron.dailyā to 2018-12-01
19:55:54 udisksd: Mounted /dev/sdc1 at /media/kmj/2TB Hard Drive on behalf of uid 1000
19:55:54 systemd: Started Clean the /media/kmj/2TB Hard Drive mount point.
19:55:54 mount.ntfs: Global ownership and permissions enforced, configuration type 7
19:55:35 systemd: Started Hostname Service.
19:55:35 dbus-daemon: [system] Successfully activated service āorg.freedesktop.hostname1ā
19:55:35 systemd: Starting Hostname Serviceā¦
19:55:35 dbus-daemon: [system] Activating via systemd: service name=āorg.freedesktop.hostname1ā unit=ādbus-org.freedesktop.hostname1.serviceā requested by ā:1.73ā (uid=1000 pid=2578 comm=āgnome-logs " label=āunconfinedā)
19:54:40 sudo: pam_unix(sudo:auth): auth could not identify password for [kmj]
19:54:22 systemd: Started Hostname Service.
19:54:22 dbus-daemon: [system] Successfully activated service āorg.freedesktop.hostname1ā
19:54:22 systemd: Starting Hostname Serviceā¦
19:54:22 dbus-daemon: [system] Activating via systemd: service name=āorg.freedesktop.hostname1ā unit=ādbus-org.freedesktop.hostname1.serviceā requested by ā:1.69ā (uid=1000 pid=2248 comm=āxfce4-terminal --preferences " label=āunconfinedā)
19:53:03 ntpd: Soliciting pool server 2a02:a18:7510:200::
19:52:37 systemd: Started Stop ureadahead data collection.
19:52:26 pulseaudio: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
19:52:26 dbus-daemon: [system] Failed to activate service āorg.bluezā: timed out (service_start_timeout=25000ms)
19:52:22 systemd: Removed slice User Slice of lightdm.
19:52:22 (sd-pam): pam_unix(systemd-user:session): session closed for user lightdm
19:52:22 systemd: Received SIGRTMIN+24 from PID 2062 (kill).
19:52:22 systemd-logind: Removed session c3.
19:52:22 systemd: Stopped Session c3 of user lightdm.
19:52:21 systemd-timesyn: Synchronized to time server 91.189.89.198:123 (ntp.ubuntu.com).
20:52:17 lightdm: pam_succeed_if(lightdm:auth): requirement āuser ingroup nopasswdloginā not met by user ākmjā
20:52:16 systemd: Started Virtual filesystem service.
20:52:16 dbus-daemon: [session uid=110 pid=1999] Successfully activated service āorg.gtk.vfs.Daemonā
20:52:16 systemd: Starting Virtual filesystem serviceā¦
20:52:16 dbus-daemon: [session uid=110 pid=1999] Activating via systemd: service name=āorg.gtk.vfs.Daemonā unit=āgvfs-daemon.serviceā requested by ā:1.1ā (uid=110 pid=1995 comm=ā/usr/sbin/slick-greeter " label=āunconfinedā)
20:52:16 systemd: Started Accessibility services bus.
20:52:16 dbus-daemon: [session uid=110 pid=1999] Successfully activated service āorg.a11y.Busā
20:52:16 systemd: Starting Accessibility services busā¦
20:52:16 dbus-daemon: [session uid=110 pid=1999] Activating via systemd: service name=āorg.a11y.Busā unit=āat-spi-dbus-bus.serviceā requested by ā:1.4ā (uid=110 pid=1995 comm=ā/usr/sbin/slick-greeter " label=āunconfinedā)
20:52:16 slick-greeter-s: New keyboard configuration: rules: evdev
model: pc105
layout: no
20:52:16 slick-greeter-c: Window scale: 1
20:52:16 dbus-daemon: [session uid=110 pid=1999] Successfully activated service āca.desrt.dconfā
20:52:16 systemd: Started D-Bus User Message Bus.
20:52:16 (systemd): pam_unix(systemd-user:session): session opened for user lightdm by (uid=0)
20:52:16 systemd: Started Session c3 of user lightdm.
20:52:16 systemd-logind: New session c3 of user lightdm.
20:52:16 systemd: Starting User Manager for UID 110ā¦
20:52:16 lightdm: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
20:52:13 nm-dispatcher: req:1 āconnectivity-changeā: start running ordered scriptsā¦
20:52:13 systemd: Started Network Manager Script Dispatcher Service.
20:11:07 pulseaudio: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
20:11:07 dbus-daemon: [system] Failed to activate service āorg.bluezā: timed out (service_start_timeout=25000ms)
20:11:02 systemd-timesyn: Synchronized to time server 91.189.91.157:123 (ntp.ubuntu.com).
21:11:01 wpa_supplicant: wlp7s6: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-36 noise=-86 txrate=240000
21:10:54 nm-dispatcher: req:1 āconnectivity-changeā: start running ordered scriptsā¦
21:10:54 systemd: Started Network Manager Script Dispatcher Service.
21:10:54 dbus-daemon: [system] Successfully activated service āorg.freedesktop.nm_dispatcherā
21:10:54 systemd: Starting Network Manager Script Dispatcher Serviceā¦
21:10:54 dbus-daemon: [system] Activating via systemd: service name=āorg.freedesktop.nm_dispatcherā unit=ādbus-org.freedesktop.nm-dispatcher.serviceā requested by ā:1.11ā (uid=0 pid=914 comm="/usr/sbin/NetworkManager --no-daemon " label=āunconfinedā)
21:10:54 NetworkManager: [1543695054.2295] manager: NetworkManager state is now CONNECTED_GLOBAL
21:10:45 ntpd: new interface(s) found: waking up resolver
21:10:43 avahi-daemon: Registering new address record for fe80::6ec6:356b:3462:3861 on wlp7s6.*.
21:10:43 ntpd: new interface(s) found: waking up resolver
21:10:42 ntpdate: the NTP socket is in use, exiting
21:10:41 pulseaudio: [pulseaudio] pid.c: Daemon already running.
21:10:41 rtkit-daemon: Supervising 7 threads of 2 processes of 1 users.
21:10:41 dbus-daemon: [system] Activating via systemd: service name=āorg.bluezā unit=ādbus-org.bluez.serviceā requested by ā:1.53ā (uid=1000 pid=1380 comm="/usr/bin/pulseaudio --start --log-target=syslog " label=āunconfinedā)
21:10:41 rtkit-daemon: Supervising 6 threads of 1 processes of 1 users.
21:10:41 systemd-resolve: Using degraded feature set (UDP) for DNS server 192.168.38.1.
21:10:41 nm-dispatcher: req:2 āupā [wlp7s6]: start running ordered scriptsā¦
21:10:41 NetworkManager: [1543695041.8739] device (wlp7s6): Activation: successful, device activated.
21:10:41 dhclient: bound to 192.168.38.113 ā renewal in 65401 seconds.
21:10:41 NetworkManager: [1543695041.8686] manager: NetworkManager state is now CONNECTED_LOCAL
21:10:41 avahi-daemon: Registering new address record for 192.168.38.113 on wlp7s6.IPv4.
21:10:41 NetworkManager: [1543695041.8637] dhcp4 (wlp7s6): state changed unknown -> bound
21:10:41 dhclient: DHCPACK of 192.168.38.113 from 192.168.38.1
21:10:41 wpa_supplicant: wlp7s6: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-48 noise=-86 txrate=1000
21:10:41 NetworkManager: [1543695041.7301] dhcp4 (wlp7s6): dhclient started with pid 1534
21:10:41 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp7s6: link becomes ready
21:10:41 wpa_supplicant: wlp7s6: CTRL-EVENT-CONNECTED - Connection to 34:21:09:2f:f0:c0 completed [id=0 id_str=]
21:10:41 systemd: Started Portal service.
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Successfully activated service āorg.freedesktop.portal.Desktopā
21:10:41 systemd: Started Portal service (GTK+/GNOME implementation).
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Successfully activated service āorg.freedesktop.impl.portal.desktop.gtkā
21:10:41 systemd: Started Virtual filesystem service - Apple File Conduit monitor.
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Successfully activated service āorg.gtk.vfs.AfcVolumeMonitorā
21:10:41 gvfs-afc-volume: Volume monitor alive
21:10:41 systemd: Starting Virtual filesystem service - Apple File Conduit monitorā¦
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Activating via systemd: service name=āorg.gtk.vfs.AfcVolumeMonitorā unit=āgvfs-afc-volume-monitor.serviceā requested by ā:1.28ā (uid=1000 pid=1422 comm="/usr/lib/x86_64-linux-gnu/tumbler-1/tumblerd " label=āunconfinedā)
21:10:41 systemd: Started Virtual filesystem service - Media Transfer Protocol monitor.
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Successfully activated service āorg.gtk.vfs.MTPVolumeMonitorā
21:10:41 systemd: Starting Portal service (GTK+/GNOME implementation)ā¦
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Activating via systemd: service name=āorg.freedesktop.impl.portal.desktop.gtkā unit=āxdg-desktop-portal-gtk.serviceā requested by ā:1.40ā (uid=1000 pid=1454 comm="/usr/lib/xdg-desktop-portal/xdg-desktop-portal " label=āunconfinedā)
21:10:41 systemd: Started Bluetooth OBEX service.
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Successfully activated service āorg.bluez.obexā
21:10:41 obexd: OBEX daemon 5.48
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Activating via systemd: service name=āorg.gtk.vfs.MTPVolumeMonitorā unit=āgvfs-mtp-volume-monitor.serviceā requested by ā:1.28ā (uid=1000 pid=1422 comm="/usr/lib/x86_64-linux-gnu/tumbler-1/tumblerd " label=āunconfinedā)
21:10:41 systemd: Started Virtual filesystem service - digital camera monitor.
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Successfully activated service āorg.gtk.vfs.GPhoto2VolumeMonitorā
Does Mint use the plugdev group?
unless you are connecting to a router or your system auto-negotiates your network cabling you will need a crossover cable if just connecting between 2 machines.
usb ports being disabled in bios by your linux os? something doesnāt sound right here!
can you post a screenshots of the bios displays relating to the usb and hdd modes?
also a distro that is not mac, linux, or windows based!
there is only two that i know of
unix, and minix
minix is a derivitive of unix and linux was designed as an alternative to minix
Is that still a thing? o_0
yes have 6 of them in my network tool bag (different lengths)
best way to isolate from a network when doing net-install and forensic work
Yeah although its a lot less mainstream these days since itās no longer needed for the uplink connection on routers.
Why do I need the cable? I am using the wifi-card. O3O
1000BASE-T spec requires Auto MDI/MDI-X, so you probably donāt need it if youāre working with anything built over the last decade; unless youāre doing hardware hacking or some other weird thing.
Well theres your problem.
Ohhhh so close! Iām sorry Sebastian, but thatās INCORRECT.
The correct answer was: āNo, we donāt shit on other peopleās hardware choices.ā
So close, so close! But you do leave home today with this car door, toilet brush, and a smile.
Better luck next time. Okay folks that about WRAPS it up today for The Internet Game Show. Tune in tomorrow, where we ssh to a Linux server, on PowerShell, ON A MAC.
That is a issue why? It worked fine with 14.04 do the fucktards at canonical not support it with 16.04 and up or something?
Someone on the LTT forum told me to try:
Nevermind, just found on the internet the issue. Linux does not like IOMMU from that motherboard, causing all sort of weird issues, and it is a never solved bug. Itās a shameā¦
However there is a workaroundā¦ as listed in
https://bugs.launchpad.net/ubuntu/+source/external-storage-manager/+bug/1447267
From what I understand, you could:
Disable IOMMU completely from the bios, overclocking settings (Iāve got an msi Mobo and that option is there, donāt ask why)
Or/Also edit /etc/default/grub
and add to where ā¦ are the other option present in there (normally splash and quiet)
GRUB_CMDLINE_LINUX_DEFAULT="ā¦ iommu=soft"
then do update-grub command, and reboot. if you want to test it this workaround āworksā, just press E on a GRUB entry from the USB live bootloader and add after the quiet and splash parameters iommu=soft
