Is the USB drive a type 2 or type 3? And what is the type of the USB you are connecting it to?
Are they of the same type?
Tried all portsā¦ Its a Razer Abyssus 2014 & Logitech K120
Okay so all those are USB 2.0, and should work in USB 3.0 ports.
By chance do you have a laptop that you could SSH into the machine in question and monitor the kernel log?
No clue how to even SSHā¦
from a linux host you just fire up a shell and type in ssh user@ip
On windows you either need to enable the WSL or download and use PuTTy.
Okay so I just plug a cable from 1 PC to the other or does this work wireless?
ssh works over the network, so as long as you have an IP address on your desktop (wifi or wired) you can enter a remote terminal session from another computer on the network.
That can work, ok I will try this! Tough I am gonna reduce the CPU speeds by 50% just incase the damn thing messes with its clocks againā¦
I got into the system without fail and saved the log from Linux Mint, it says a lot in here is there a way to copy paste it from the log file into the forum?
Click the gear icon, hide details, and then stick your stuff in there. Between code ticks.
[details="Summary"] ``` code goes here ``` [/details]
Well I got the file out before the USB died on me can I get the stuff out in Windows or do I have to move it to my laptop?
which log file did you grab?
ALL of it.
Specifically where?
Also, if you machine is still powered on and you have the ssh session open, type dmesg
for me.
19:55:35 systemd: Started Hostname Service.
19:55:35 dbus-daemon: [system] Successfully activated service 'org.freedesktop.hostname1'
19:55:35 systemd: Starting Hostname Service...
19:55:35 dbus-daemon: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.73' (uid=1000 pid=2578 comm="gnome-logs " label="unconfined")
19:54:40 sudo: pam_unix(sudo:auth): auth could not identify password for [kmj]
19:54:22 systemd: Started Hostname Service.
19:54:22 dbus-daemon: [system] Successfully activated service 'org.freedesktop.hostname1'
19:54:22 systemd: Starting Hostname Service...
19:54:22 dbus-daemon: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.69' (uid=1000 pid=2248 comm="xfce4-terminal --preferences " label="unconfined")
19:53:03 ntpd: Soliciting pool server 2a02:a18:7510:200::
19:52:37 systemd: Started Stop ureadahead data collection.
19:52:26 pulseaudio: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
19:52:26 dbus-daemon: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
19:52:22 systemd: Removed slice User Slice of lightdm.
19:52:22 (sd-pam): pam_unix(systemd-user:session): session closed for user lightdm
19:52:22 systemd: Received SIGRTMIN+24 from PID 2062 (kill).
19:52:22 systemd-logind: Removed session c3.
19:52:22 systemd: Stopped Session c3 of user lightdm.
19:52:21 systemd-timesyn: Synchronized to time server 91.189.89.198:123 (ntp.ubuntu.com).
20:52:17 lightdm: pam_succeed_if(lightdm:auth): requirement "user ingroup nopasswdlogin" not met by user "kmj"
20:52:16 systemd: Started Virtual filesystem service.
20:52:16 dbus-daemon: [session uid=110 pid=1999] Successfully activated service 'org.gtk.vfs.Daemon'
20:52:16 systemd: Starting Virtual filesystem service...
20:52:16 dbus-daemon: [session uid=110 pid=1999] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.1' (uid=110 pid=1995 comm="/usr/sbin/slick-greeter " label="unconfined")
20:52:16 systemd: Started Accessibility services bus.
20:52:16 dbus-daemon: [session uid=110 pid=1999] Successfully activated service 'org.a11y.Bus'
20:52:16 systemd: Starting Accessibility services bus...
20:52:16 dbus-daemon: [session uid=110 pid=1999] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.4' (uid=110 pid=1995 comm="/usr/sbin/slick-greeter " label="unconfined")
20:52:16 slick-greeter-s: New keyboard configuration: rules: evdev
model: pc105
layout: no
20:52:16 slick-greeter-c: Window scale: 1
20:52:16 dbus-daemon: [session uid=110 pid=1999] Successfully activated service 'ca.desrt.dconf'
20:52:16 systemd: Started D-Bus User Message Bus.
20:52:16 (systemd): pam_unix(systemd-user:session): session opened for user lightdm by (uid=0)
20:52:16 systemd: Started Session c3 of user lightdm.
20:52:16 systemd-logind: New session c3 of user lightdm.
20:52:16 systemd: Starting User Manager for UID 110...
20:52:16 lightdm: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
20:52:13 nm-dispatcher: req:1 'connectivity-change': start running ordered scripts...
20:52:13 systemd: Started Network Manager Script Dispatcher Service.
20:52:13 dbus-daemon: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
20:52:13 systemd: Starting Network Manager Script Dispatcher Service...
20:52:13 dbus-daemon: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.14' (uid=0 pid=921 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined")
20:52:13 NetworkManager: <info> [1543693933.1556] manager: NetworkManager state is now CONNECTED_GLOBAL
20:52:04 wpa_supplicant: wlp7s6: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-36 noise=-86 txrate=300000
20:52:04 systemd: Started flatpak system helper.
20:52:04 dbus-daemon: [system] Successfully activated service 'org.freedesktop.Flatpak.SystemHelper'
20:52:04 systemd: Starting flatpak system helper...
20:52:04 dbus-daemon: [system] Activating via systemd: service name='org.freedesktop.Flatpak.SystemHelper' unit='flatpak-system-helper.service' requested by ':1.58' (uid=1000 pid=1440 comm="flatpak update -y " label="unconfined")
20:52:04 flatpak: libostree pull from 'flathub' for appstream2/x86_64 complete
security: GPG: summary+commit http: TLS
non-delta: meta: 5 content: 19
transfer: secs: 1 size: 1,6 MB
20:52:03 ntpd: new interface(s) found: waking up resolver
20:52:03 wpa_supplicant: wlp7s6: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-37 noise=-86 txrate=300000
I see that the bluez daemon failed to load, which would cause bluthooth devices to not work.
Unable to post anything in 19 hoursā¦
Nov 25 19:56:41 ntpd: Soliciting pool server 2a02:a18:7510:200::
Nov 25 19:56:22 dbus-daemon: [system] Reloaded configuration
Nov 25 19:56:22 systemd: Reloading.
Nov 25 19:56:20 wpa_supplicant: wlp7s6: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-46 noise=-86 txrate=270000
Nov 25 19:56:20 systemd: Started LSB: automatic crash report generation.
Nov 25 19:56:20 apport: ā¦done.
Nov 25 19:56:20 systemd: Starting LSB: automatic crash report generationā¦
Nov 25 19:56:17 dbus-send: method return time=1543172177.309625 sender=org.freedesktop.DBus -> destination=:1.82 serial=3 reply_serial=2
Nov 25 19:56:17 dbus-daemon: [system] Reloaded configuration
Nov 25 19:56:17 systemd: Reloading D-Bus System Message Bus.
Nov 25 19:56:16 dbus-daemon: [system] Reloaded configuration
Nov 25 19:56:16 systemd: Reloading.
Nov 25 19:56:16 udisksd: Acquired the name org.freedesktop.UDisks2 on the system message bus
Nov 25 19:56:16 systemd: Started Disk Manager.
Nov 25 19:56:15 udisksd: Failed to load the āmdraidā libblockdev plugin
Nov 25 19:56:15 systemd: Starting Disk Managerā¦
Nov 25 19:56:15 udisksd: udisks daemon version 2.7.6 exiting
Nov 25 19:56:15 systemd: Stopping Disk Managerā¦
Nov 25 19:56:15 dbus-daemon: [system] Reloaded configuration
Nov 25 19:56:14 systemd: Reloading.
Nov 25 19:56:11 packagekitd: daemon quit
Nov 25 19:56:11 systemd: Reloaded D-Bus System Message Bus.
Nov 25 19:56:11 dbus-send: method return time=1543172171.166429 sender=org.freedesktop.DBus -> destination=:1.79 serial=3 reply_serial=2
Nov 25 19:56:11 dbus-daemon: [system] Reloaded configuration
Nov 25 19:56:11 systemd: Reloading D-Bus System Message Bus.
Nov 25 19:56:10 dbus-daemon: [system] Reloaded configuration
Nov 25 19:56:10 systemd: Started Dispatcher daemon for systemd-networkd.
Nov 25 19:56:10 networkd-dispat: WARNING: systemd-networkd is not running, output will be incomplete.
Nov 25 19:56:10 systemd: Starting Dispatcher daemon for systemd-networkdā¦
Nov 25 19:55:48 dbus-send: method return time=1543172148.343512 sender=org.freedesktop.DBus -> destination=:1.77 serial=3 reply_serial=2
Nov 25 19:55:48 dbus-daemon: [system] Reloaded configuration
Nov 25 19:55:48 systemd: Reloading D-Bus System Message Bus.
Nov 25 19:55:46 systemd: Reloading.
Nov 25 19:55:45 dbus-daemon: [system] Reloaded configuration
Nov 25 19:55:45 systemd: Reloading.
Nov 25 19:55:44 kernel: debug: running subtest /usr/lib/os-probes/mounted/efi
Nov 25 19:55:41 kernel: QNX4 filesystem 0.2.3 registered.
Nov 25 19:55:41 kernel: ntfs: driver 2.1.32 [Flags: R/O MODULE].
Nov 25 19:55:41 kernel: JFS: nTxBlock = 8192, nTxLock = 65536
Nov 25 19:55:41 kernel: SGI XFS with ACLs, security attributes, realtime, no debug enabled
Nov 25 19:55:40 avahi-daemon: No service file found in /etc/avahi/services.
Nov 25 19:55:38 kernel: audit: type=1400 audit(1543172138.518:52): apparmor=āSTATUSā operation=āprofile_replaceā info=āsame as current profile, skippingā profile=āunconfinedā name=āman_groffā pid=21714 comm=āapparmor_parserā
Nov 25 19:55:38 kernel: kauditd_printk_skb: 16 callbacks suppressed
Nov 25 19:55:38 apparmor_parser: AVC apparmor=āSTATUSā operation=āprofile_replaceā info=āsame as current profile, skippingā profile=āunconfinedā name=āman_groffā pid=21714 comm=āapparmor_parserā
Nov 25 19:55:38 ntpd: receive: Unexpected origin timestamp 0xdfa56ea3.829a215b does not match aorg 0000000000.00000000 from [email protected] xmt 0xdfa56eaa.7015fb57
Nov 25 19:55:25 NetworkManager: [1543172125.0475] supplicant: wpa_supplicant die count reset
Nov 25 19:55:24 systemd: Reloading.
Nov 25 19:55:24 grub-common: ā¦done.
Nov 25 19:55:24 systemd: Starting LSB: Record successful boot for GRUBā¦
Nov 25 19:55:24 ntpd: Soliciting pool server 77.95.77.250
Nov 25 20:58:41 systemd-journal: Time spent on flushing to /var is 7.727ms for 977 entries.
Nov 25 20:58:41 systemd: Started udev Kernel Device Manager.
Nov 25 20:58:41 keyboard-setup.: cannot open file /tmp/tmpkbd.S96gRp
Nov 25 20:58:41 kernel: Inserted module āparport_pcā
Nov 25 20:58:41 systemd-journal: Runtime journal (/run/log/journal/0be4b885ddb347e5bc70559303dca99f) is 8.0M, max 160.4M, 152.4M free.
Nov 25 20:58:41 kernel: ppdev: user-space parallel port driver
Nov 25 20:58:41 kernel: lp: driver loaded but no devices found
Nov 25 20:58:41 kernel: EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
Nov 25 20:58:41 kernel: Listening on /dev/initctl Compatibility Named Pipe.
Nov 25 20:58:41 kernel: Created slice System Slice.
Nov 25 20:58:41 kernel: Reached target System Time Synchronized.
Nov 25 20:58:41 kernel: Set up automount Arbitrary Executable File Formats File System Automount Point.
Nov 25 20:58:41 kernel: Started Forward Password Requests to Wall Directory Watch.
Nov 25 20:58:41 kernel: Set hostname to .
Nov 25 20:58:41 kernel: Detected architecture x86-64.
Nov 25 20:58:41 kernel: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
Nov 25 20:58:41 kernel: ip_tables: Ā© 2000-2006 Netfilter Core Team
Nov 25 20:58:41 kernel: EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
Nov 25 20:58:41 kernel: clocksource: Switched to clocksource tsc
Nov 25 20:58:41 kernel: Btrfs loaded, crc32c=crc32c-intel
Nov 25 20:58:41 kernel: xor: automatically using best checksumming function avx
Nov 25 20:58:41 kernel: raid6: using ssse3x2 recovery algorithm
Nov 25 20:58:41 kernel: [drm] {1920x1080, 2200x1125@148500Khz}
Nov 25 20:58:41 kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x420bee34340, max_idle_ns: 440795428783 ns
Nov 25 20:58:41 kernel: tsc: Refined TSC clocksource calibration: 4581.982 MHz
Nov 25 20:58:41 kernel: [drm] Initialized amdgpu 3.23.0 20150101 for 0000:03:00.0 on minor 0
Nov 25 20:58:41 kernel: amdgpu 0000:03:00.0: kfd not supported on this ASIC
Nov 25 20:58:41 kernel: Console: switching to colour frame buffer device 240x67
Nov 25 20:58:41 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Nov 25 20:58:41 kernel: [drm] pitch is 7680
Nov 25 20:58:41 kernel: sd 3:0:0:0: [sdd] Attached SCSI disk
Nov 25 20:58:41 kernel: sdd: sdd1 sdd2
Nov 25 20:58:41 kernel: sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 20:58:41 kernel: scsi 3:0:0:0: Direct-Access ATA ST2000DX001-1NS1 CC41 PQ: 0 ANSI: 5
Nov 25 20:58:41 kernel: ata4.00: configured for UDMA/133
Nov 25 20:58:41 kernel: [drm] UVD and UVD ENC initialized successfully.
Nov 25 20:58:41 kernel: sd 2:0:0:0: [sdc] Attached SCSI disk
Nov 25 20:58:41 kernel: sdc: sdc1
Nov 25 20:58:41 kernel: [drm] ring test on 11 succeeded in 11 usecs
Nov 25 20:58:41 kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Nov 25 20:58:41 kernel: sdb: sdb1 sdb2 sdb3 sdb4 sdb5
Nov 25 20:58:41 kernel: sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 20:58:41 kernel: scsi 2:0:0:0: Direct-Access ATA ST2000DM001-1ER1 CC25 PQ: 0 ANSI: 5
Nov 25 20:58:41 kernel: sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Nov 25 20:58:41 kernel: scsi 1:0:0:0: Direct-Access ATA Samsung SSD 850 1B6Q PQ: 0 ANSI: 5
Nov 25 20:58:41 kernel: ata2.00: configured for UDMA/133
Nov 25 20:58:41 kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 20:58:41 kernel: scsi 0:0:0:0: Direct-Access ATA Samsung SSD 850 1B6Q PQ: 0 ANSI: 5
Nov 25 20:58:41 kernel: ata2.00: NCQ Send/Recv Log not supported
Nov 25 20:58:41 kernel: ata1.00: configured for UDMA/133
Nov 25 20:58:41 kernel: ata2.00: supports DRM functions and may not be fully accessible
Nov 25 21:12:52 systemd-journal: Time spent on flushing to /var is 6.525ms for 974 entries.
Nov 25 21:12:52 systemd: Starting Flush Journal to Persistent Storageā¦
Nov 25 21:12:52 keyboard-setup.: cannot open file /tmp/tmpkbd.S96gRp
Nov 25 21:12:52 systemd-modules: Inserted module āppdevā
Nov 25 21:12:52 systemd-journal: Runtime journal (/run/log/journal/0be4b885ddb347e5bc70559303dca99f) is 8.0M, max 160.4M, 152.4M free.
Nov 25 21:12:52 kernel: EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
Nov 25 21:12:52 kernel: parport0: irq 0 detected
Nov 25 21:12:52 kernel: ppdev: user-space parallel port driver
Nov 25 21:12:52 kernel: lp: driver loaded but no devices found
Nov 25 21:12:52 kernel: Starting Load Kernel Modulesā¦
Nov 25 21:12:52 kernel: Listening on Journal Socket.
Nov 25 21:12:52 kernel: Created slice System Slice.
Nov 25 21:12:52 kernel: Reached target Remote File Systems.
Nov 25 21:12:52 kernel: Started Forward Password Requests to Wall Directory Watch.
Nov 25 21:12:52 kernel: Created slice User and Session Slice.
Nov 25 21:12:52 kernel: Set hostname to .
Nov 25 21:12:52 kernel: Detected architecture x86-64.
Nov 25 21:12:52 kernel: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
Nov 25 21:12:52 kernel: ip_tables: Ā© 2000-2006 Netfilter Core Team
Nov 25 21:12:52 kernel: EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
Nov 25 21:12:52 kernel: Btrfs loaded, crc32c=crc32c-intel
Nov 25 21:12:52 kernel: xor: automatically using best checksumming function avx
Nov 25 21:12:52 kernel: raid6: using ssse3x2 recovery algorithm
Nov 25 21:12:52 kernel: [drm] {1920x1080, 2200x1125@148500Khz}
Nov 25 21:12:52 kernel: clocksource: Switched to clocksource tsc
Nov 25 21:12:52 kernel: tsc: Refined TSC clocksource calibration: 4581.983 MHz
Nov 25 21:12:52 kernel: [drm] Initialized amdgpu 3.23.0 20150101 for 0000:03:00.0 on minor 0
Nov 25 21:12:52 kernel: amdgpu 0000:03:00.0: kfd not supported on this ASIC
Nov 25 21:12:52 kernel: Console: switching to colour frame buffer device 240x67
Nov 25 21:12:52 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Nov 25 21:12:52 kernel: [drm] pitch is 7680
Nov 25 21:12:52 kernel: sd 3:0:0:0: [sdd] Attached SCSI disk
Nov 25 21:12:52 kernel: sdd: sdd1 sdd2
Nov 25 21:12:52 kernel: sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 21:12:52 kernel: scsi 3:0:0:0: Direct-Access ATA ST2000DX001-1NS1 CC41 PQ: 0 ANSI: 5
Nov 25 21:12:52 kernel: ata4.00: configured for UDMA/133
Nov 25 21:12:52 kernel: sd 2:0:0:0: [sdc] Attached SCSI disk
Nov 25 21:12:52 kernel: sdc: sdc1
Nov 25 21:12:52 kernel: ata4.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
Nov 25 21:12:52 kernel: [drm] UVD and UVD ENC initialized successfully.
Nov 25 21:12:52 kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Nov 25 21:12:52 kernel: sdb: sdb1 sdb2 sdb3 sdb4 sdb5
Nov 25 21:12:52 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Nov 25 21:12:52 kernel: sda: sda1 sda2
Nov 25 21:12:52 kernel: sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 21:12:52 kernel: scsi 2:0:0:0: Direct-Access ATA ST2000DM001-1ER1 CC25 PQ: 0 ANSI: 5
Nov 25 21:12:52 kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 21:12:52 kernel: scsi 1:0:0:0: Direct-Access ATA Samsung SSD 850 1B6Q PQ: 0 ANSI: 5
Nov 25 21:12:52 kernel: ata2.00: configured for UDMA/133
Nov 25 21:12:52 kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesnāt support DPO or FUA
Nov 25 21:12:52 kernel: ata2.00: NCQ Send/Recv Log not supported
19:58:41 systemd: Started Hostname Service.
19:58:41 dbus-daemon: [system] Successfully activated service āorg.freedesktop.hostname1ā
19:58:41 systemd: Starting Hostname Serviceā¦
19:58:41 dbus-daemon: [system] Activating via systemd: service name=āorg.freedesktop.hostname1ā unit=ādbus-org.freedesktop.hostname1.serviceā requested by ā:1.79ā (uid=1000 pid=2578 comm="gnome-logs " label=āunconfinedā)
19:56:54 anacron: Job cron.daily' terminated 19:56:52 rsyslogd: [origin software="rsyslogd" swVersion="8.32.0" x-pid="929" x-info="http://www.rsyslog.com"] rsyslogd was HUPed 19:56:52 systemd: Started Make remote CUPS printers available locally. 19:56:51 logger: no dictionary update necessary. 19:56:51 anacron: Updated timestamp for job
cron.dailyā to 2018-12-01
19:55:54 udisksd: Mounted /dev/sdc1 at /media/kmj/2TB Hard Drive on behalf of uid 1000
19:55:54 systemd: Started Clean the /media/kmj/2TB Hard Drive mount point.
19:55:54 mount.ntfs: Global ownership and permissions enforced, configuration type 7
19:55:35 dbus-daemon: [system] Successfully activated service āorg.freedesktop.hostname1ā
19:55:35 systemd: Starting Hostname Serviceā¦
19:55:35 dbus-daemon: [system] Activating via systemd: service name=āorg.freedesktop.hostname1ā unit=ādbus-org.freedesktop.hostname1.serviceā requested by ā:1.73ā (uid=1000 pid=2578 comm=āgnome-logs " label=āunconfinedā)
19:54:22 dbus-daemon: [system] Successfully activated service āorg.freedesktop.hostname1ā
19:54:22 systemd: Starting Hostname Serviceā¦
19:54:22 dbus-daemon: [system] Activating via systemd: service name=āorg.freedesktop.hostname1ā unit=ādbus-org.freedesktop.hostname1.serviceā requested by ā:1.69ā (uid=1000 pid=2248 comm=āxfce4-terminal --preferences " label=āunconfinedā)
19:52:26 dbus-daemon: [system] Failed to activate service āorg.bluezā: timed out (service_start_timeout=25000ms)
20:52:17 lightdm: pam_succeed_if(lightdm:auth): requirement āuser ingroup nopasswdloginā not met by user ākmjā
20:52:16 dbus-daemon: [session uid=110 pid=1999] Successfully activated service āorg.gtk.vfs.Daemonā
20:52:16 systemd: Starting Virtual filesystem serviceā¦
20:52:16 dbus-daemon: [session uid=110 pid=1999] Activating via systemd: service name=āorg.gtk.vfs.Daemonā unit=āgvfs-daemon.serviceā requested by ā:1.1ā (uid=110 pid=1995 comm=ā/usr/sbin/slick-greeter " label=āunconfinedā)
20:52:16 dbus-daemon: [session uid=110 pid=1999] Successfully activated service āorg.a11y.Busā
20:52:16 systemd: Starting Accessibility services busā¦
20:52:16 dbus-daemon: [session uid=110 pid=1999] Activating via systemd: service name=āorg.a11y.Busā unit=āat-spi-dbus-bus.serviceā requested by ā:1.4ā (uid=110 pid=1995 comm=ā/usr/sbin/slick-greeter " label=āunconfinedā)
model: pc105
layout: no
20:52:16 dbus-daemon: [session uid=110 pid=1999] Successfully activated service āca.desrt.dconfā
20:52:16 systemd: Starting User Manager for UID 110ā¦
20:52:13 nm-dispatcher: req:1 āconnectivity-changeā: start running ordered scriptsā¦
20:11:07 pulseaudio: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
20:11:07 dbus-daemon: [system] Failed to activate service āorg.bluezā: timed out (service_start_timeout=25000ms)
20:11:02 systemd-timesyn: Synchronized to time server 91.189.91.157:123 (ntp.ubuntu.com).
21:11:01 wpa_supplicant: wlp7s6: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-36 noise=-86 txrate=240000
21:10:54 nm-dispatcher: req:1 āconnectivity-changeā: start running ordered scriptsā¦
21:10:54 systemd: Started Network Manager Script Dispatcher Service.
21:10:54 dbus-daemon: [system] Successfully activated service āorg.freedesktop.nm_dispatcherā
21:10:54 systemd: Starting Network Manager Script Dispatcher Serviceā¦
21:10:54 dbus-daemon: [system] Activating via systemd: service name=āorg.freedesktop.nm_dispatcherā unit=ādbus-org.freedesktop.nm-dispatcher.serviceā requested by ā:1.11ā (uid=0 pid=914 comm="/usr/sbin/NetworkManager --no-daemon " label=āunconfinedā)
21:10:54 NetworkManager: [1543695054.2295] manager: NetworkManager state is now CONNECTED_GLOBAL
21:10:45 ntpd: new interface(s) found: waking up resolver
21:10:43 avahi-daemon: Registering new address record for fe80::6ec6:356b:3462:3861 on wlp7s6.*.
21:10:43 ntpd: new interface(s) found: waking up resolver
21:10:42 ntpdate: the NTP socket is in use, exiting
21:10:41 pulseaudio: [pulseaudio] pid.c: Daemon already running.
21:10:41 rtkit-daemon: Supervising 7 threads of 2 processes of 1 users.
21:10:41 dbus-daemon: [system] Activating via systemd: service name=āorg.bluezā unit=ādbus-org.bluez.serviceā requested by ā:1.53ā (uid=1000 pid=1380 comm="/usr/bin/pulseaudio --start --log-target=syslog " label=āunconfinedā)
21:10:41 rtkit-daemon: Supervising 6 threads of 1 processes of 1 users.
21:10:41 systemd-resolve: Using degraded feature set (UDP) for DNS server 192.168.38.1.
21:10:41 nm-dispatcher: req:2 āupā [wlp7s6]: start running ordered scriptsā¦
21:10:41 NetworkManager: [1543695041.8739] device (wlp7s6): Activation: successful, device activated.
21:10:41 dhclient: bound to 192.168.38.113 ā renewal in 65401 seconds.
21:10:41 NetworkManager: [1543695041.8686] manager: NetworkManager state is now CONNECTED_LOCAL
21:10:41 avahi-daemon: Registering new address record for 192.168.38.113 on wlp7s6.IPv4.
21:10:41 NetworkManager: [1543695041.8637] dhcp4 (wlp7s6): state changed unknown -> bound
21:10:41 dhclient: DHCPACK of 192.168.38.113 from 192.168.38.1
21:10:41 wpa_supplicant: wlp7s6: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-48 noise=-86 txrate=1000
21:10:41 NetworkManager: [1543695041.7301] dhcp4 (wlp7s6): dhclient started with pid 1534
21:10:41 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp7s6: link becomes ready
21:10:41 wpa_supplicant: wlp7s6: CTRL-EVENT-CONNECTED - Connection to 34:21:09:2f:f0:c0 completed [id=0 id_str=]
21:10:41 systemd: Started Portal service.
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Successfully activated service āorg.freedesktop.portal.Desktopā
21:10:41 systemd: Started Portal service (GTK+/GNOME implementation).
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Successfully activated service āorg.freedesktop.impl.portal.desktop.gtkā
21:10:41 systemd: Started Virtual filesystem service - Apple File Conduit monitor.
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Successfully activated service āorg.gtk.vfs.AfcVolumeMonitorā
21:10:41 gvfs-afc-volume: Volume monitor alive
21:10:41 systemd: Starting Virtual filesystem service - Apple File Conduit monitorā¦
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Activating via systemd: service name=āorg.gtk.vfs.AfcVolumeMonitorā unit=āgvfs-afc-volume-monitor.serviceā requested by ā:1.28ā (uid=1000 pid=1422 comm="/usr/lib/x86_64-linux-gnu/tumbler-1/tumblerd " label=āunconfinedā)
21:10:41 systemd: Started Virtual filesystem service - Media Transfer Protocol monitor.
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Successfully activated service āorg.gtk.vfs.MTPVolumeMonitorā
21:10:41 systemd: Starting Portal service (GTK+/GNOME implementation)ā¦
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Activating via systemd: service name=āorg.freedesktop.impl.portal.desktop.gtkā unit=āxdg-desktop-portal-gtk.serviceā requested by ā:1.40ā (uid=1000 pid=1454 comm="/usr/lib/xdg-desktop-portal/xdg-desktop-portal " label=āunconfinedā)
21:10:41 systemd: Started Bluetooth OBEX service.
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Successfully activated service āorg.bluez.obexā
21:10:41 obexd: OBEX daemon 5.48
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Activating via systemd: service name=āorg.gtk.vfs.MTPVolumeMonitorā unit=āgvfs-mtp-volume-monitor.serviceā requested by ā:1.28ā (uid=1000 pid=1422 comm="/usr/lib/x86_64-linux-gnu/tumbler-1/tumblerd " label=āunconfinedā)
21:10:41 systemd: Started Virtual filesystem service - digital camera monitor.
21:10:41 dbus-daemon: [session uid=1000 pid=1246] Successfully activated service āorg.gtk.vfs.GPhoto2VolumeMonitorā
If they canāt install a working Linux, then that wonāt fit the bill either. Just saying. OP asked for alt os that isnāt linux, mac or windowsā¦
I gave them another option I know of, that runs on common hardware. There is a version of Solaris that will run on x86_64, but I think that would be even more of a lost cause.
With the ssh session open, remove your keyboard and mouse from the remote machine (desktop), and then reconnect them.
From the ssh session type in dmesg
and then if there are any errors surrounding your mouse and keyboard they would appear at the bottom and most recent, and most likely in red as errors.
Could it be just a hardware fault. This is the worst part of PC problems. Not having hardware to swap out. Maybe the MB is bad.
