Desktop Monitor
Hey... again I just bought this http://m.newegg.com/Product/index?itemNumber=N82E16883227425
(Sorry for the mobile link but I'm on my phone right now) I'm looking for a monitor to use with that computer that is around 1600x900. I don't care for built in speakers as I'll just plug some of mine in to the thing. 18 to 20" is all I want. Obviously I just want something that will look good doing light gaming with no dead pixels and crap. Finally, my budget is $100 to $130. Thanks and sorry for the loads of threads different help, going from a mediocre pc to a gaming computer is a feat that requires help.
Any Asus TN panel in that price range will do
What games you play?
http://pcpartpicker.com/p/l8CW
Here's a 21.5" for about $110.00, it's at 1920x1080 but you can always set the resolution to 1600x900 and you will have access to 1080p if you go that route in the future. If you get a native 1600x900 you'll be spending about the same amount unless you get something used. So it's kinda future proof(ish) for what you will need it to do.
Thanks! I'll be looking into this suggestion!
Skyrim, Minecraft, and all games in the Arma series
http://www.newegg.com/Product/Product.aspx?Item=N82E16824176422
Hm... the reviews for that PC really aren't too good. Idk if I'd trust that mine wouldn't have the same problems that seem to be coming up alot.
I kept retyping my comment to convey my dismay, then I just settled on this image.
BenQ GW2250 if you can find one, they are about 110-120$ and are better than TN panels by a HUGE ammount
YUP , get that, then connect it via dvi, and try to overclock the refresh rate to about 75hz via nvidia control panel and you will have a pretty kick ass setup for around 1k
