Might be the “fix” for us. If I can get this abomination of a 3900X/B350 setup networked I’ll be testing Fedora 41 Beta with it to see if it does things properly.
I wound up putting the 6700 back in my 5950X system, and making the jump to Fedora 41B, since I failed to sort out a networking solution for the 3900X.
Audio issues didn’t go away, but were about the least bad I’ve had them. Then it started failing to wake from sleep pretty consistently. Then it would refuse to POST; it’d iterate through CPU/RAM/wake LEDs, but it couldn’t wake the 6700. Weird. One occasion it eventually turned CSM on along with a message about the VGA card not having UEFI support. Then it just quit posting, so I threw the 580 back in and it’s been the usual dead reliable I expect from it. So I tried the 6700 again, aaaaaaaand it was reliably crashing with artifacting immediately preceding. Weirdly, when it would artifact out and then crash, it never dropped audio until it dropped the card entirely.
It’s /possible/ that there are bugs in 6.11 and/or F41B, but it’s also possible that some of the instability moments I had on F40 with the 9700X were the 6700 and not the quite heavily overtuned CO/CS settings I was toying with.
I think my overall conclusion is Burn Navi.
Just as a diagnostic, try driving that TV 1080p @ 30 Hz and see if anything about the audio improves.
Newly equipped with yet another warranty replacement 6700, I have new and exciting failure modes to report!
- Audio problems are moderately better on 6.11+ kernels than they were on 6.10 by quite some margin, so that’s nice.
- This is something I don’t fully understand. On suspend, the 6700 will reliably crash out and refuse to wake after some indefinite time. On attempted reboot, it’ll hit the VGA step and just go “nope”. The first two examples would skip the BIOS splash screen and then wake up on OS loading (across both Windows and Linux), but these two just hang. A restart command from a working state goes fine and continues display in BIOS, but a shutdown command starts a fun and exciting world of forcing a safe mode boot, at which point it’ll POST and function until the next.
I got tired of my music skipping on HDMI and shut the X570 rig down. Stuck the 6700 into a B350 board I have laying around. No POST. Sweet. Eventually force safe mode boot, works, goes to OS. Restart command works, succesfully reboots and displays BIOS and goes into OS. Shut down command shuts down as expected, aaaaaaaaaaand then doesn’t POST. And that board isn’t nice enough to have debug LEDs, nor can I trigger the safe mode on it without CMOS reset. However, it doesn’t appear to be CSM that “fixes” the no-POST condition, as CSM was very definitely on in the B350’s case.
Edit:
Did try this. It changed absolutely nothing, though 59.94/.97hz settings did make small differences on frequency of occurrence some of the time. Other video cards, such as an RX 580 or Arc A770, have absolutely no trouble whatsoever in this regard even at 3840x2160 60hz.
So, I had a 6750XT briefly. Paired it with Arrow Lake; worked well enough, except the damn audio. Same situations, same trials and tribulations as the 6700 on AM4+AM5. Was a reference cooler, memory temps were horrendous. Swapped for a B580 at the tail end of the extended return period.
B580 got around the audio, but performed way below expected in some games. And then when I went to retest it I had LACT installed, and it erroneously sets a maximum power limit of like 40W for it that seems to persist both after reboots and after disabling overclocking. I should look into that further. Anyway, switched back to the 6700 specifically for Tokyo Xtreme Racer.
But here’s where I’m really curious. There was the 6.11 kernel change that helped the audio clipping absolutely massively, but it’s still present under certain scenarios. The one that I can replicate repeatedly that I truly, absolutely fail to understand? Newegg. Having a Newegg tab open and audio playing, regardless of if it’s locally stored music via any given audio player application or a Youtube video consistently starts clipping. No direct interaction with the webpage is necessary, and it doesn’t have to be a tab that’s currently displayed. Some other webpages do it too, but… How can a webpage that is primarily text and images cause my audio to cut in and out?
