Desktop build help plz
Hey,
So I'm building a desktop for my cousin and the main thing there are going to be doing is streaming & recording them self drawing at the same time and sometimes running a small minecraft server or something.
So I've got experience building computers but I didn't know what I needed to focus on more, the CPU or RAM or GPU
I got this motherboard to use http://www.mwave.com.au/product/gigabyte-ga970ad3p-am3-motherboard-ab50201#detailTabs=tabSpecifications
i got hard drives and case for them and just need the help with getting a cpu with more cores or more ram or putting the left over money into a better gpu
Thanks in advance
Probably for streaming/ mc server I'd sink more money into the CPU than the GPU. You could grab an 8350 which is great for streaming and probably works fine for a mc server, something like 12gb of RAM (although 8 would probably be fine) and a decent*ish* GPU. Up to you, though.
+1
but try for a FX-8320 since its like $30 to $40 cheaper and it gets pretty close proformance and then put the  extra money in a gpu
+1
The 8320 would probably be your best choice, but may be a bit flaky on that motherboard.
So do you reckon these specs would run smoothly with streaming and recording at the same time. The budget is about $700
Mobo -  http://www.mwave.com.au/product/gigabyte-ga970ad3p-am3-motherboard-ab50201
CPU -  http://www.mwave.com.au/product/amd-fx6300-black-edition-6core-socket-am3-cpu-processor-aa18167
RAM -  http://www.mwave.com.au/product/geil-evo-veloce-8gb-ddr3-2x-4gb-ddr3-1600mhz-memory-gev38gb1600c11dc-ab51960
GPU -  http://www.mwave.com.au/product/gigabyte-geforce-gtx-650-oc-1gb-video-card-aa77676
HDD -  http://www.mwave.com.au/product/western-digital-wd10ezrx-wd-1tb-green-35-intellipower-sata3-hard-drive-aa19746#detailTabs=tabSpecifications
PSU -  http://www.mwave.com.au/product/aywun-mega-power-elite-series-650w-power-supply-atxeps-aa49394#detailTabs=tabOverview
Case -  http://www.mwave.com.au/product/silverstone-rl01-redline-black-case-window-usb30-aa12578
I have the 8320,You can OC the cpu without even touching the voltage,just go into the bios and set the multiplier to 20.5. It will clock the chip at 4118 mhz or so. It runs perfectly stable and cooler than it did before,don't know why,but before I disabled the turbo it used to overvolt the cpu. I got my 8320 on a rebate - 90$ cheaper than a 8350.
