Desk build with NO BUDGET (unlimited)
Ok lets get down to .... no songs ....
I've always been amazed at the desk build computers, the neatness, clean look the idea and overall feel that "you (I) did this!"
well this will be my frist post ever on this site mostly cause r/buildapc and /diy/ really didn't help and such.
This computer is to be used as a workstation video render and 3d cad like stuff and extreme gaming (aka ENB skyrim stuff cause i casual extreme gamer)
SPECS:
-Supermicro H8QGL-IF-O
http://www.superbiiz.com/detail.php?name=MB-H8QGLIF&c=FR&pid=0f201db0658857e83a399410ef205ddfd17925cacbae1ddf77505af97628983b
-AMD OPTERON 16 core @ 2.6Ghz turbo 3.3Ghz x4
http://www.superbiiz.com/detail.php?name=OS-6282SE
-Samsung 8Gb 1600mhz ECC x16
http://www.superbiiz.com/detail.php?name=D38GE1600S
-Samsung 840 256gb ssd x3
http://www.superbiiz.com/detail.php?name=MZ-7PD256Z
-Seagate constellation es.3 2TB 128MB cache x2
http://www.superbiiz.com/detail.php?name=HD-ST20NM3
-Alphacool 480mm rad 80mm thick x4 (1 per cpu i know crazy)
http://www.frozencpu.com/products/16237/ex-rad-412/Alphacool_NexXxoS_Monsta_Quad_120mm_Radiator_-_80mm_Thick.html?tl=g30c95s570
-Alphacool 240mm rad 80mm thick x2 (1 per gpu unknown model as of yet [looking at some 7990's or a few fire pros])
http://www.frozencpu.com/products/16236/ex-rad-410/Alphacool_NexXxoS_Monsta_Dual_120mm_Radiator_-_80mm_Thick.html?tl=g30c95s160
-Alphacool ram water block x16 (don't know if i put half the ram in 1 of the gpu rads and the other half in the other gpu rad orrrrrrrrr a seprate rad)
http://www.frozencpu.com/products/20804/ex-blc-1489/Alphacool_NexXxoS_RXP-1_RAM-Cooler_DDR1DDR2DDR3_-_G14_-_Black_Nickel.html?tl=g30c225s557
the desk and resvoirs and pump are to come due to the desk planing and stuff as such i want to keep the rads atleast 3'6" away from the mobo and low noise and good pump quality i have done water and liquid cooling before but its never been this big and with no budget (woooo getting some inheritance money).
and one thing i can't find is a psu with 3x8pin 12v connections for cpu power can i molex it?
my main questions are about:
-pumps... how far can i pump well with low nosie and efficiently?
-resvoirs... what coolent would be best in this type of enviorment?
-gpu.... out put to 6 monitors at 1080p/1440p? is my target range better will make me happy i have all the monitors btw
any help with this is loved i will post pics of the desk once i finish ordering the wood and black scinice room table top
thanks
george
aka sink
For video card maybe one of these http://www.newegg.com/Product/Product.aspx?Item=N82E16814195116  I would rather have an NVIDIA http://www.newegg.com/Product/Product.aspx?Item=N82E16814133347 but it wont do 6 monitors. And things get tricky when you start mixing and matching videocards. I am a fan of AMD however in the professional graphics department they tend to have driver problems with software like AutoCAD and solid works. I am not fermiliar with gaming development and rendering software so that my not be an issue.
No budget? Get 4 titans.
He can't get 4 Titans; that Supermicro board only has 3x PCIe x16 2.0 slots, if I recall correctly, from when I was researching my 4P build (which is coming, expect something awesome). I'd get dual 7990s, and have that extra x16 slot for an SSD, or something like a RAID card.
As for pumps, I would either get triple DDCs or dual D5s, both with either mod tops, like Petra's top or the EK top for the DDC, or the Bitspower top for the D5s. Good ones include the Swiftech MCP355 for DDCs and Swiftech MCP655-B for the D5s. More pumps = lower RPM per = lower noise = more redundancy for more awesome.
Go ahead and get some 16GB ECC sticks of RAM; you can max that board at 512GB, if you want, and have some insane RAM disks.
4 cards is just retarded, anything more than dual cards is pointless.
No... Triple cards scales the best, anyway.
Why not wait for a bit and see what AMD has in store for the next gen? Shouldn't be too long I suppose
Professional graphics and gaming graphics are not created equal. There are some solidworks builds that would absolutly shit all over the titan If there is no budget then you should build two systems. One for work and one for play.
If he got two 7990s and a Firepro, like a V7900, he could Fold on two 7970s, game on two 7970s, and render on the Firepro. He would be the destroyer of worlds.
W00T UNLIMITED BUDGET!??
Here http://pcpartpicker.com/p/1tmdP I call this bulid-THE MOTHERFUCKER.
Silly, silly by. You think a 3960X is better than 64 cores of Opteron? And Titans? In an editing rig? Oh, there is so much to teach you...
Then teach me master.
MORE CORES, MOTHERFUCKER.
I GET IT MOAR CORES MORE POWAAAAAAAAAAAAA!!!!!!!!!!!!!!!!
thank you for taking in the fact of the x16 lanes most people never see that on these types of builds. I'm looking into a few models of 7990 cant find a single one with 6 outputs that has a good enough base clock speed that isn't voltage locked.... might go 2x2  with these http://www.amazon.com/Dell-UltraSharp-U2913WM-29-Inch-Ultra-Wide/dp/B00B0ARE12/ref=sr_1_1?ie=UTF8&qid=1376854616&sr=8-1&keywords=dell+29+inch+monitor to get the feel. the reason i really don't wanna go 512gb is then the speed of the ram drops its 128-256gb 1866mhz max but at 512gb its 1333mhz max it funny how that is but i could get a diffrent board and that issue would be fixed but then i lose on sata ports and PCIe ports
the pumps it looks as the MCP355 would work best! 5 of the buggers with housing to keep it clean looking. 4 1per prosssesor and 1 for gpu's and ram
I would put more cooling intothe GPUs than the CPUs. A single 480 would cool all 4 of those CPUs. I would put two 480s to the CPUs, and two 480s to the GPUs, because with 7990s, you have two 7970s per card, which takes a lot of cooling.
I'd personally get a single 4k monitor than use several lower-res monitors.
Are you high?
Maybe?
hmmmm could do that just move around the 480 config and put the 240's on the ram
the reason against the 4k is would i not have any content to use on the 4k. 4k will get better later and will have content to display later i'll wait till then.
amd is skiping the 8xxx series giving the 8xxx series to the OEM's...
9xxx is not really going to be much of a bouns to the to me unless the top of the line card is going to be 9990 and has like a 2ghz clock speed and 8gb gddr5 it really isn't going to help
