Delta fans in a node 304?
Is it a good or bad idea? Or should I use noctua fans or something else?
WIND TUNNEL!
use noctua, corsair, or cougar fans, much quieter and you get more airflow/pressure when used at the same noise level
You won't do it you're scared..
And in case you're not scared and you actually do it please let me know before you turn your PC on so that I can step out of the way of the blackhole it will create.
Huston, we are ready for take off!
Linus (from 'le Tech Tips) recommends Noctua fans.
I'd look into the NZXT 120mm Performance Case Fan; they are cheap, perform well, and are decently quiet.
You might want to mount a few 92mm deltas in there for enhanced sonic performance.
Yes he will want 2 92mm deltas for the front and a 140mm for the back for max lift.
But actually if you are on a budget I would look at Enermax fans they are good and cheap get the twister blades if possible.
Corsair seem to do a nice fan, I recently purchased a twin pack of AF120's.
So if I do get node 304 I should use all delta fans. Just for the lols. Right now its a toss up between the 304 and the ft03b mini.
I have a 304 and I can say that it is a great case
I like both cases the FT03b takes up less space but the Node 304 has a little bit more room.
Get http://www.frozencpu.com/products/7868/fan-483/Delta_92mm_x_38mm_Super_High-Speed_Fan_-_17503_CFM_PFB0912DHE.html?tl=g36c15s700 and http://www.frozencpu.com/products/8147/fan-500/Delta_Mega_Fast_120mm_x_38mm_Fan_-_252_CFM_-_Bare_Lead_PFB1212UHE-F00.html?tl=g36c15s562
Don't forget to use earplugs and bolt down your Node 304.Enjoy epic cooling performance :D
