Dell mobo unknown model number
guys is there any way to find what type of mobo your computer has besides like gpuz
list anything besides that and i will try it
btw my computer is pre built thats why im asking
" Record the BIOS ID string, which will be located at the bottom-left corner during startup. On most systems, you can press the Pause key during the memory test to suspend the process and allow more time to properly copy the ID string."
- http://motherboards.mbarron.net/bios.html#who
Hopfully that helps
thanks
What do you want to know?
The board model number or what is on the board for components?
The first is easy, just check on the board, it's written.
The second is as easy, just get EVEREST Ultimate.
