Hello,
I bought a second hand Dell Latitude XT2 with Windows 7 64-bit on it. When I got it home, I tested if everything worked, and yes everything functioned perfectly. A few weeks later, I installed a trail version of Windows 8. I thought; the new Windows 8 might work well on my touchscreen laptop! .... Nope. I uninstalled it a week later.
But when I returned to Windows 7, my Touchscreen stopped working.
When I took a look at the device manager in Windows 7, it displayed a unknown USB device. I knew this had to be a driver issue, so I downloaded the recommended drivers from Dell's site and installed them. When I did that the driver program responded in saying that I didn't have a Touchscreen. Okay, I then checked the official site and downloaded the drivers from there. Nope, still nothing.
I have no Idea how to fix this problem. Anyone have a suggestion?
Drivers: http://www.dell.com/support/drivers/us/en/19/product/latitude-xt2
Specs if they are of any help:
CPU - Intel Mobile Core 2 Duo @ 1.40GHz
RAM - 3GB DDR3 @ 667MHz
HDD - 250GB
BIOS - Dell Inc. version A15
