Dell Inspiron 530 dual gigabit ethernet?
Hi guys im making my old dell inspiron 530 into a PF sense router.
And am looking for a dual gigabit network card. I have seen that the machine has a PCIE slot, so I could buy this
http://www.ebay.co.uk/itm/HP-NC360T-Dual-Port-Gigabit-NIC-PCI-E-Server-Adaptor-PCIE-Full-Height-Card-DP-FH-/400429353287?pt=UK_Computing_ComputerComponents_InterfaceCards&hash=item5d3b730947.
Slots not matching
but the slots don't seem to match up to my inspiron :(  http://imgur.com/z77rEsj The PCIE seems to be inverted is this due to the way im looking at the image on ebay or will it not fit?.
Mix and match PCI types?
My second question is can I buy a PCIE ethernet/gigabit card and also fit a second "standerd" PCI ethernet/gigabit card and they will all be able to work in the same machine at the same time.
WAN/incoming data connection?
Lastly due to me using a stock talk talk router right now which has a modem built in. Can i just connect the inspiron to the router via a ethernet cable, making the talk talk router into a modem. So that the talk talk router takes care of the internet connection. And the inspiron/PFsense router takes care of lan firewalls etc.
Thanks
