Define r5
Is this the same case, I am confused because one says black pearl and one doesn't?
http://www.scan.co.uk/products/fractal-design-define-r5-black-mid-tower-atx-matx-mini-itx-computer-chassis-with-window-usb-30-plus-
or
You can see that product code matches, so it's the same thing. Also, there's Titanium version which is almost exactly the same thing as black, only slightly brighter front door.
Cool, thanks for the reply, I am going for a stealth build so the black one is the one
I have the R5 titanium.
It looks like this
As in, the "titanium" part is barely grey.
Also, case is great.
Yeah, I have been planning this build for months so exited also I love the sleek look of this case, is it as quiet as people say.
These are my parts if your interested
i7 6700k
Asus z170 -A
16gb DDR4
EVGA 980 ti superclocked+
define r5
500gb ssd
650w G2
If you remove the top panel - not really, no... The noise dampening is gone...
If it is quiet with removed top panel - you probably didn't need silent case anyway..
I am mounting the 240mm rad for the h100i GTX in the front so i can leave all the modi vents or whatever they call them in for the silence.
I have the Define R4 on a previous build. I chose it for its noise dampening and indeed I was happy with it. My only complaint was that behind the motherboard tray there was not alot of room to route cable and it was a little struggle to put on the back panel.
My next build after the new year will have this case for sure and I will probably stick to the silent rig aspect again. Plonk Noctua fans in it.
I was also looking at the Fractal Design Kelvin S36 to put in it as well.
Pearl is not correct but the black one is correct from what i am guessing.
