Define r4 with nh-d15
Hi guys!
What do you think? it is possible to fit a Noctua nh-d15 in a Fractal Design r4 with 4 Gskill RipjawsX Rams?
Thanks!
you will need low profile ram, but it should fit
Yes it works, i have a nhd 15 with an r5, and before i had an R4, both fit fine
Well, then I don't have any further excuses for not to buy it :) Thanks for your feedback.
No problem
I use the d14 in my define r4 with corsair vengeance pro sticks.  It works but I did have to raise the front fan a little bit when clamping it to the heatsink structure in order to clear the ram.
It is OK for me as far as you can close the case.
I just want to give you a feedback. It fits nicely in the case, and works like a charm.
