Define R4 Graphics Card Problem
I bought a gtx 760 to put in my new pc and it wont slide all the way back into the pci-e slot. I've heard of the happening with cheaper cases, but this a a fairly high quality case. What should I do?
Give it a wiggle, sometimes the teeth at the back of the bracket can be finicky
Thanks, but that didnt work, just tried it. :(
I got it to work by putting some stress on the teeth in the slots, went right in after. :)
