I am building a new PC using a Fractal Design Define R4 case, which is a really nice piece.
I understand Logan, and possibly others, use this as their personal case. May I ask, do any of you have a recommended setup for the case fans?
I am air cooling the CPU (i5 4670k w/ Noctua NH-U12S), single GPU etc, and I plan on using this PC for gaming, mildly overclocked.
I am trying to weigh having 2 front intakes (140mm) and 1 rear exhaust (140mm) vs. the same setup + 2 more 140mm fans on top for additional exhaust.
Given the amount of venting all over the rear of the case, I have trouble believing the air is going to be overly pressurized, so airflow seems to be the real goal.
This article from bit-tech has all the information you'll probably ever need to know about fan set-up on a case. As an added bonus, the tests were made with Define R3,
You won't need to open the top. Two front and the single rear exhaust will be fine with this build. Have the motherboard control the fans if it's got good settings, or use the Define R4's integrated fan controller and set the fans to low or medium as temperature readings suggest. For my own 3570K and HD7950-boost system everything has been fine with the low setting even in the summer.
The fans that come with the case are good enough to keep using too, which is not always something one can count on with fans that come included. For instance you could put those two fans in the front and have some other 140mm at the exhaust, or simply get a third of the same model Silent Series R2 140mm fan. No need for any really expensive fans in general.
My overall goal is to keep a low noise level. Excessive airflow only gives you more dust in the case. ;)
I did noticed when I removed the ModuVents from the top, the top panel was kinda flexible. It bowed (very minor with a clunk) when I moved the case around. Maybe the ModuVents add sturdiness to the top?
Yes the top is a wee bit flimsy without anything screwed in. Keep the ModuVents in or screw in fans there later. The top of a case tends to be an ideal place for noise to leak out if open, but it depends on positioning too of course.
Two front intakes, rear exhaust and vents closed is about the worst set-up you can do with 3 fans in this case. I really recommend reading the contents of the link I provided, at least take a look at the data.
Well that's good and all as far as maximising cooling with a certain number of fans goes. But that doesn't mean that the cooling will end up being insufficient, when in fact it will be fine. The system will stay pretty quiet and most of the intake air will be filtered.
That article is good but it's not something you'd necessarily want to follow in every build just because. There are often more factors to consider.
Hmm, it seems that a 5 fan setup using both fronts and the bottom as intakes and the rear + top-rear for exhaust might be best, since I have the 5 fans to use. Could tie the 3 intakes into the front panel fan controller and plug the exhausts into the mobo.
That will certainly be a nice setup. The intakes could run with the controller at its low setting, as long as all the fans are able to start up on 5V like the ones that come with the case.
I simply just got extras of the same FD fans that came with the case. I know they aren't they world's most ZOMGWTFBBQ fans but they are reviewed well enough, were on sale and match the rest of the case fans.
