Ok guys I'm thinking about buying a Titan for a dedicated PhysX card. I have a GT680 for GPU right now and I really want two Titans for PhysX but i don't know. Is this worth the money?
The GTX 680's offer a much better bang for the buck. Get two of them instead
I really hope you are trolling...
wait... a gt 680 as a primary gpu and a titan just for the physx? What?
Ya, i mean that's gonna be good right?
Don't know if serious...
Dlorehwardna, your Profile description:
I'm Andrew, switched from console gaming in late 2012....
Ok, I get it. If you buy a titan (Holy crap, you want 2 of these?) you won't be able to use it with a gt680. That you are saying deticated physx shows me, that you have confused physx a bit. If you have an AMD card, you can add a deticated physx card. (some nvidia card with physx, with software from modders/hackers). Because AMD has no physx out of the box. Well there is also another way:
http://www.youtube.com/watch?v=O_VE5yqNbLg
you get nearly everything
By the way, you can also grab a gtx 670 or 680. If you are just gaming. (Or rendering?!) The Titan is either a luxury, or server/work stuff.
A gt680.....Why...GT...
