Deciding on new video card or keep old one
I have an alienware x51 with a i5 2320 at 3.0ghz(3.4ghz with turbo), curently i have to gt 545 gddr5 with 1gb of memory. Should i upgrade to a gtx 660 ti or just stay with the gt 545?
get a new card.
If you have SLI 545 GDDR5, the 660ti should be about twice power, though that doesn't meen you will see twice the frames, its probably worth it. Btw, those cards sell for about $50 each new, so... You could sell them? :)
Well its only one so i'll probally sell the one and buy the evga gtx 660 ti, so i'm just going to buy the gtx 660 thank you.
If you do end up selling your card I am looking for one for my HTPC that can play games :)
Upgrading in an x51 is quite difficult in all honesty, make sure the card you want will fit in your system first and wont have any ventilation issues because they are very compact as you might have noticed.
d3athgat0r i can sell it to you when i get my 660, and cheetoh alienware has a model that comes with a 660 ti, some on youtube have put 680s in there systems so there shouldn't be any problem with ventalation
