Anyone have any experience running Debian 12 on a 2012 Macbook Air. I tried Mint Live w/ XFDE and LMDE and they seem to run fine, but I would rather just have Debian since that’s what I run on my old laptop and I would rather trust an older stable OS that isn’t over bloated and also this will be for a family member which means I can provide help easier if I share the same platform. I prefer KDE Plasma it looks nice and feels snappier.
Is this an A1466? I like the adapter to put a cheap NVMe drive in where the supplied thumb storage lives, it helps keep an older machine snappy. I’ve had my A1502-type MacBook Pro 13" happy under Debian 12 Bookworm, mostly web browsing is OK but some video decoding does tax the CPU and cause the fans to whirr.
K3n.
I’ve run KDE on a 2010/2011-ish air a couple of years and the performance was quite sluggish, but it only had 2GB of ram.
My 8th gen Intel T480 with 32 GB ram struggles with some of the webapps I use regularly. If you intend to run something like electron apps on a 2012 low power Intel CPU (or just modern webapps/sties) you need to arm yourself with some patience.
I would look for something even more lightweight, maybe something without systemd. KDE is probably fine if it has enough ram, but if it only has 2GB you should consider getting a fast SSD and load it with swap.
Note: I have a bunch of very fast computers with a shitload of RAM so my perspective may be skewed.
They still need to back up their files, so I don’t have access to the machine. But it was 2012 (Canada) and she said they got the most expensive loadout for it as far as she remembers, she thought it was a 2011 but it has 8GB ram and the 2011 only had the option for 4GB.
My alternate DE choice would be Mate, but someone said that KDE Plasma isn’t much heavier than Mate, and I prefer KDE Plasma.
It will be for web browsing and Youtube, maybe some LibreOffice stuff and Teams meetings.
Not sure, I don’t have access to the machine until she gets around to backing up some of the files on it. I feel like the Pro has quite a bit better hardware, I might just have to run it for a bit to test. Is there any packages that I can get that would optimize the experience a bit?
If Plasma is too heavy, take a look at LXQT.
I usually install zram-tools and would recommend that to swap to compressed RAM rather than to disk, even if you have added a NVMe SSD.
K3n.
If you only need the basic ‘desktop’ take a look at IceWM, I’ve run that on less-than-potato class computers with great success.
