Title pretty much explains it all. I need a GPU that will show better performance than my current GPU, which is a GTX 680. I don't need to upgrade it, I just want to get a new GPU that is better than it, that's all. It is very good GPU, but I know there is better.
I just need a beast of a GPU that can handle any game maxed out and at the same time, be cosmetically satisfying (because the side window is massive on the Obsidian 750D). Right now, the Titan has both of those, and maybe the 290X a little bit.
Let me know what GPU would be best for me. I am gaming in a single monitor at 1920x1080, and at the moment price is not an issue.
Also: with Black Friday coming up, will any of these items be on sale?
Personaly i would actually go for the r9 290 not the x model at the moment but you would have to wait for the aftermarket cooled ones. I cant really say anything about mantle and the other thingys that are coming out but if its anything that has been said it would push the card for even better performance and then theres the true audio thingy if you care about such
Well, AMD have come out and said that Mantle will not be exclusive to AMD.
I'd grab the 780ti, personally. Greatest amount of performance, without a Titan price tag. But I would only really recommend that if you used an appropriate display. e.g 1440p
Otherwise, the 290 with a third party cooler will have the best price to performance at 1080p.
Since you're gaming at 1080p there isn't much of a reason to upgrade from a 680. You should be able to run pretty much everything out there on max settings if not close already. If your frame rate is low with a 680 I'd be looking to other components causing a bottleneck... cpu.. mb.. etc...
As for purchasing a card that can support 4k gaming.. there aren't many monitor options that are reasonably priced unless you are looking at a seiki tv to use as a monitor.. even then there is a low refresh rate.
4k is the next big thing and well sure it is available all these new cards score very low fps running at those resolutions, the technology is just not far enough along to justify an upgrade over an already great card. Especially if you're only gaming at 1080p.
Even single monitor 1440p or 1600p a 680 should be able to perform very well.
If you are looking to do a multimonitor setup I'd pick up a 290 or 290x because of the 4gb of vram as well as the price. Titan is expensive, is outperformed by a 780ti, a 780ti lacks the vram for multimonitor gaming imo and both are far more expensive then a 290/290x.
I've got a Gtx 770, so the same as a 680, I run surround 3+1, I can play some games in surround with some lowered settings that just aren't important to me and for those that need full attention of the gpu I play them single monitor.
I'd say save your money for a future build and if you're confident enough, flash the 680 with a 770 bios. If you brick your card then you have a reason to upgrade :p.
Well depends on what you want. Have you though about a new monitor then look at some with the new technology G-sync by Nvidia and go with their new GPU's and if its just for entertainment not 3d heavy applications go 780 Ti looks nice better performance for gaming and with the saved money, look at a Nvidia shield you can do some awesome,things with that like stream games to it and play your pc games that accept this and play them on your TV or what have you. If you plan on getting a 4k monitor later get a 290x or even 2 of them and would benefit you even more if mantel takes off like AMD is hoping.
