Hi Logan and Team,
I opened up my laptop because the raid array failed but when i put it back together again there was this.
Are these pixels dead, hot, stuck or what????
Thanks
You are BAU5!!!! :)
http://www.mediafire.com/?26hlso3m1f27vkm
Hi Logan and Team,
Thanks
You are BAU5!!!! :)
No Picture on your message.
This really doesn't need to be in inbox.exe.
dunno seems a bit too "messy" for dead pixels, perhaps you messed up the connections inside when you opened it up. Probably around the hinge area where they usually run the screen cable. If thats the pic in LA33R's post.
Or someones been coloring your screen with blue felt tips lol, looks like fluid or something, not ever seen dead pixels look like that.
i updated it
You may have cracked the bottom of your lcd, on the inside.
So im screwed? New screen?
Try reconnecting it. If it's still messed up, new screen or deal with the broken-ness.
Leaving it as it is certainly wont hurt anything, if you can deal with it.
you might be able to set up a custom resolution+screen positioning in the driver so its not on the actual viewable area
Could it be replaced under warranty?
If youve opened it up and broken seals etc i highly doubt any warranty would still be valid. you could always try and bs tho
It looks like fluid or something, although it reminds me of my tv with ants under the screen.
Looks like cracked LCD, not dead pixels.
Ouch, cracked LCD.
Is that a laptop?
If yes, thats a cracked lcd, no repairment.
