KVM Model:
HDMI 2.1 KVM w/EDID & Serial Control - Dual Monitor - Four Computer
10Gb
Problem:
Hi, I’m trying to use DDC to control monitor brightness (through Lunar). When the monitor is connected directly to my computer (MacBook Pro 16-inch 2019 - i9), then the brightness control works. When I connect it through the KVM, the tool cannot control the monitor. I’m having LG 32UL950.
Is DDC/CI something that should be supported on this KVM?
