I’m running on Fedora 28. See oclDeviceQuery output below. OpenCL sees my CPU, but there’s no mention of my Vega 56.
./oclDeviceQuery
[oclDeviceQuery] starting…
./oclDeviceQuery Starting…
OpenCL SW Info:
WARNING: NVIDIA OpenCL platform not found - defaulting to first platform!
CL_PLATFORM_NAME: Portable Computing Language
CL_PLATFORM_VERSION: OpenCL 1.2 pocl 1.1 RelWithDebInfo, LLVM 6.0.1, SPIR, SLEEF, DISTRO, POCL_DEBUG
OpenCL SDK Revision: 7027912
OpenCL Device Info:
1 devices found supporting OpenCL:
Device pthread-AMD Ryzen 7 1700 Eight-Core Processor
CL_DEVICE_NAME: pthread-AMD Ryzen 7 1700 Eight-Core Processor
CL_DEVICE_VENDOR: AuthenticAMD
CL_DRIVER_VERSION: 1.1
CL_DEVICE_VERSION: OpenCL 1.2 pocl HSTR: pthread-x86_64-unknown-linux-gnu-znver1
CL_DEVICE_OPENCL_C_VERSION: OpenCL C 1.2 pocl
CL_DEVICE_TYPE: CL_DEVICE_TYPE_CPU
CL_DEVICE_MAX_COMPUTE_UNITS: 16
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS: 3
CL_DEVICE_MAX_WORK_ITEM_SIZES: 4096 / 4096 / 4096
CL_DEVICE_MAX_WORK_GROUP_SIZE: 4096
CL_DEVICE_MAX_CLOCK_FREQUENCY: 3000 MHz
CL_DEVICE_ADDRESS_BITS: 64
CL_DEVICE_MAX_MEM_ALLOC_SIZE: 8192 MByte
CL_DEVICE_GLOBAL_MEM_SIZE: 30066 MByte
CL_DEVICE_ERROR_CORRECTION_SUPPORT: no
CL_DEVICE_LOCAL_MEM_TYPE: global
CL_DEVICE_LOCAL_MEM_SIZE: 4096 KByte
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE: 4096 KByte
CL_DEVICE_QUEUE_PROPERTIES: CL_QUEUE_PROFILING_ENABLE
CL_DEVICE_IMAGE_SUPPORT: 1
CL_DEVICE_MAX_READ_IMAGE_ARGS: 128
CL_DEVICE_MAX_WRITE_IMAGE_ARGS: 128
CL_DEVICE_SINGLE_FP_CONFIG: denorms INF-quietNaNs round-to-nearest round-to-zero round-to-inf fma
CL_DEVICE_IMAGE 2D_MAX_WIDTH 16384
2D_MAX_HEIGHT 16384
3D_MAX_WIDTH 2048
3D_MAX_HEIGHT 2048
3D_MAX_DEPTH 2048
CL_DEVICE_EXTENSIONS: cl_khr_byte_addressable_store
cl_khr_global_int32_base_atomics
cl_khr_global_int32_extended_atomics
cl_khr_local_int32_base_atomics
cl_khr_local_int32_extended_atomics
cl_khr_3d_image_writes
cl_khr_spir
cl_khr_fp64
cl_khr_int64_base_atomics
cl_khr_int64_extended_atomics
CL_DEVICE_PREFERRED_VECTOR_WIDTH_ CHAR 16, SHORT 16, INT 8, LONG 4, FLOAT 8, DOUBLE 4
2D Image Formats Supported (31)
Channel Order Channel Type
1 CL_A CL_SNORM_INT8
2 CL_A CL_SNORM_INT16
3 CL_A CL_UNORM_INT8
4 CL_A CL_UNORM_INT16
5 CL_A CL_SIGNED_INT8
6 CL_A CL_SIGNED_INT16
7 CL_A CL_SIGNED_INT32
8 CL_A CL_UNSIGNED_INT8
9 CL_A CL_UNSIGNED_INT16
10 CL_A CL_UNSIGNED_INT32
11 CL_A CL_FLOAT
12 CL_RGBA CL_SNORM_INT8
13 CL_RGBA CL_SNORM_INT16
14 CL_RGBA CL_UNORM_INT8
15 CL_RGBA CL_UNORM_INT16
16 CL_RGBA CL_SIGNED_INT8
17 CL_RGBA CL_SIGNED_INT16
18 CL_RGBA CL_SIGNED_INT32
19 CL_RGBA CL_UNSIGNED_INT8
20 CL_RGBA CL_UNSIGNED_INT16
21 CL_RGBA CL_UNSIGNED_INT32
22 CL_RGBA CL_HALF_FLOAT
23 CL_RGBA CL_FLOAT
24 CL_ARGB CL_SNORM_INT8
25 CL_ARGB CL_UNORM_INT8
26 CL_ARGB CL_SIGNED_INT8
27 CL_ARGB CL_UNSIGNED_INT8
28 CL_BGRA CL_SNORM_INT8
29 CL_BGRA CL_UNORM_INT8
30 CL_BGRA CL_SIGNED_INT8
31 CL_BGRA CL_UNSIGNED_INT8
3D Image Formats Supported (31)
11 CL_A CL_FLOAT
23 CL_RGBA CL_FLOAT
oclDeviceQuery, Platform Name = Portable Computing Language, Platform Version = OpenCL 1.2 pocl 1.1 RelWithDebInfo, LLVM 6.0.1, SPIR, SLEEF, DISTRO, POCL_DEBUG, SDK Revision = 7027912, NumDevs = 1, Device = pthread-AMD Ryzen 7 1700 Eight-Core Processor
System Info:
Local Time/Date = 10:45:02, 04/14/2019
CPU Name: AMD Ryzen 7 1700 Eight-Core Processor
of CPU processors: 16
Linux version 5.0.6-100.fc28.x86_64 ([email protected]) (gcc version 8.3.1 20190223 (Red Hat 8.3.1-2) (GCC)) #1 SMP Wed Apr 3 16:14:34 UTC 2019
[oclDeviceQuery] test results…
PASSED
exiting in 3 seconds: 3…2…1…done!
