Hey folks.
So my nextcloud postgres docker database desided to literally grenade itself randomly somehow without warning, nor power outtage, nor data corruption on the ZFS Raid Z2 array
The server just responds with internal error
2022-05-27 18:08:43.328 MDT [46752] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:43.328 MDT [46752] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:43.422 MDT [46753] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:43.422 MDT [46753] CONTEXT: automatic analyze of table "nextcloud.public.oc_appconfig"
2022-05-27 18:08:43.433 MDT [46753] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:43.433 MDT [46753] CONTEXT: automatic analyze of table "nextcloud.public.oc_jobs"
2022-05-27 18:08:43.903 MDT [46754] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:43.903 MDT [46754] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:44.298 MDT [46755] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:44.298 MDT [46755] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:44.547 MDT [46756] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:44.547 MDT [46756] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:44.800 MDT [46757] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:44.800 MDT [46757] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:45.096 MDT [46758] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:45.096 MDT [46758] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:45.097 MDT [46758] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:45.097 MDT [46758] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:45.416 MDT [46759] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:45.416 MDT [46759] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:46.929 MDT [46760] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:46.929 MDT [46760] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:47.202 MDT [46761] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:47.202 MDT [46761] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:47.203 MDT [46761] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:47.203 MDT [46761] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:47.497 MDT [46762] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:47.497 MDT [46762] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:47.498 MDT [46762] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:47.498 MDT [46762] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:47.801 MDT [46763] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:47.801 MDT [46763] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:47.802 MDT [46763] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:47.802 MDT [46763] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:48.138 MDT [46764] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:48.138 MDT [46764] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:48.459 MDT [46765] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:48.459 MDT [46765] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:48.947 MDT [46774] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:48.947 MDT [46774] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:48.948 MDT [46774] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:48.948 MDT [46774] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:49.432 MDT [46775] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:49.432 MDT [46775] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:50.135 MDT [46776] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:50.135 MDT [46776] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:50.451 MDT [46777] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:50.451 MDT [46777] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:50.452 MDT [46777] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:50.452 MDT [46777] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:50.866 MDT [46778] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:50.866 MDT [46778] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:51.180 MDT [46779] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:51.180 MDT [46779] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:51.181 MDT [46779] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:51.181 MDT [46779] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:51.490 MDT [46780] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:51.490 MDT [46780] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:51.491 MDT [46780] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:51.491 MDT [46780] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:51.807 MDT [46781] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:51.807 MDT [46781] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:51.808 MDT [46781] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:51.808 MDT [46781] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:52.307 MDT [46782] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:52.307 MDT [46782] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:52.308 MDT [46782] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:52.308 MDT [46782] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:52.618 MDT [46783] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:52.618 MDT [46783] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:52.916 MDT [46784] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:52.916 MDT [46784] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:53.224 MDT [46785] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:53.224 MDT [46785] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:53.225 MDT [46785] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:53.225 MDT [46785] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:53.487 MDT [46786] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:53.487 MDT [46786] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:53.488 MDT [46786] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:53.488 MDT [46786] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:53.987 MDT [46787] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:53.987 MDT [46787] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:54.528 MDT [46788] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:54.528 MDT [46788] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:54.529 MDT [46788] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:54.529 MDT [46788] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:54.846 MDT [46789] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:54.846 MDT [46789] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:55.168 MDT [46790] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:55.168 MDT [46790] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:55.490 MDT [46791] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:55.490 MDT [46791] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:55.807 MDT [46792] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:55.807 MDT [46792] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:55.808 MDT [46792] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:55.808 MDT [46792] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:56.135 MDT [46793] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:56.135 MDT [46793] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:56.821 MDT [46794] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:56.821 MDT [46794] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:57.079 MDT [46795] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:57.079 MDT [46795] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:57.422 MDT [46796] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:57.422 MDT [46796] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:57.725 MDT [46797] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:57.725 MDT [46797] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:57.726 MDT [46797] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:57.726 MDT [46797] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:58.055 MDT [46798] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:58.055 MDT [46798] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:58.711 MDT [46799] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:58.711 MDT [46799] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:59.189 MDT [46808] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:59.189 MDT [46808] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:08:59.747 MDT [46809] ERROR: cache lookup failed for index 3379
2022-05-27 18:08:59.747 MDT [46809] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:00.023 MDT [46810] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:00.023 MDT [46810] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:00.280 MDT [46811] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:00.280 MDT [46811] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:00.281 MDT [46811] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:00.281 MDT [46811] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:00.572 MDT [46812] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:00.572 MDT [46812] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:00.871 MDT [46813] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:00.871 MDT [46813] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:01.114 MDT [46814] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:01.114 MDT [46814] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:01.370 MDT [46815] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:01.370 MDT [46815] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:01.371 MDT [46815] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:01.371 MDT [46815] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:01.694 MDT [46816] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:01.694 MDT [46816] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:02.015 MDT [46817] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:02.015 MDT [46817] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:02.282 MDT [46818] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:02.282 MDT [46818] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:02.522 MDT [46819] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:02.522 MDT [46819] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:02.523 MDT [46819] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:02.523 MDT [46819] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:02.794 MDT [46820] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:02.794 MDT [46820] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:02.795 MDT [46820] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:02.795 MDT [46820] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:03.321 MDT [46821] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:03.321 MDT [46821] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:03.322 MDT [46821] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:03.322 MDT [46821] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:03.606 MDT [46822] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:03.606 MDT [46822] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:03.924 MDT [46823] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:03.924 MDT [46823] STATEMENT: SELECT * FROM "oc_appconfig"
2022-05-27 18:09:03.925 MDT [46823] ERROR: cache lookup failed for index 3379
2022-05-27 18:09:03.925 MDT [46823] STATEMENT: SELECT * FROM "oc_appconfig"
Thats the endless error. please tell me this is recoverable in someway shape or form. I have no clue how it happened. Im looking for solutions and both google and duckduckgo yield me nothing for this specific index
Any and all useful help is appreciated!
