Darksiders 2 issues
it run a lil slow sometimes i think because my CPU gets to 48C & GPU gets up to 47C heres a list of my GPU CPU & PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161404    GPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727    CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010    PSU
Uhhh, 48 and 47 degrees is FANTASTICALLY good temps for a CPU or GPU. And all of the things you  have there are high quality, so I'm not sure what the problem is. Are you sure your drivers are up to date?
sometimes its 50c im a bit worried about my temp rather have em at 30c
& my drivers are up to date
50C is fine, there is no way while gaming your temps will stay as low as 30c, unless you do some unothodox and crazy cooling.
so i geuss its my game then still gonna buy that coller master CPu heatsink fan
