Dark Rock Pro 4 intermittent fan noise solved
I wanted to put this goof somewhere, maybe it will help others troubleshoot similar issues.
I have a Dark Rock Pro 4 TR4 cooler and ever since it was on, I kept hearing these 4 little knocks or bumps every couple of seconds. First I thought it was one of the system fans, because I had a couple of really old ones in there.
3 case fans total, stopped each one, the noise kept going off like clockwork. The strange thing was that it wasn’t a constant noise that would indicate busted ball bearings or something.
So I got to the CPU cooler, which I didn’t want to believe could be bad since it was brand new, stopped the front fan, still noise. Well crap, then it has to be the fan between the two towers, now I have to dig it out.
The fan was backwards. The two fans were working against each other. The middle fan, being more obstructed, probably kept turning off and then on again, which made the intermittent noise.
Lesson: if others help out with a build, double-check their work.
