Damaged a component near am5 socket, now mb won't power on
Hello,
While trying a new cooler I managed to destroy a component near the socket of my MSI PRO B650-P WIFI motherboard and now it won’t power on. While searching online, I noticed that many am5 board had the component but still I could not find what it was.
Please if anyone has any info on what that compent is it would be very helpful.
Thank you
Pretty sure that was a crystal that got knocked off.
I’m guessing the larger 4 terminal oscillator next to it can’t give a stable output without it.
Thank you for the info. Would you now which specific crystal oscillator would I need to replace it with?
Thanks again
You don’t happen to have the Crystal that fell off do you? It’d probably have a code on the top that specifies it’s frequency.
It looks like the actual oscillator on the motherboard says it’s 48.000MHz, but I wouldn’t automatically assume that means the discrete crystal is also 48.000MHz; I’m not vary familiar with the kind of clocking circuit they are using, but I image it would be common among most of MSI’s AM5 motherboards.
