Daily router reset
Everyday around 7pm , get the explanation mark on my internet icon, unplug dat ethernet plug it back it, internet still doesn't work, why would it. Go to router all the lights are on normally unplug that bitch for about 30 seconds. Plug it back in, same lights are on. Go back have internet. Why.
Router problem, try updating the router.
The router might be failing, ISP is being a douchedick, or firmware needs to be updated. and also put this in the networking hardware to help organize a little better
If the router is older than 5yrs, then replace with a new one or update the firmware. If that doesnt' fix the problem then take your size 10 boots to your ISP's derrier until it's fixed.
Post in the correct section next time... moved -.-"
I wish I had that power to move networking questions into the networking forums
some routers suck.. some simply run slower the longer they're on to the point that they move 0.1k a second or some crap out for various reasons and eventually require a reset.  next time you buy a router do some research on it and it's chipset. it really doesn't even matter the brand, some can overheat or some didn't suck hard enough so they put out a "revision" which has an entirely different chipset and will now crash randomly. firmware updates dont always fix the problem, stuff like this has pissed people off so bad in the past they have either hacked their router up or installed custom firmware like tomato.
*COUGH*UBEE*COUGH*TIME*COUGH*WARNER*COUGH*
You're power is only assigned for the Networking section. Moving requires full access to the whole forum.
exactly his point.
I feel his pain. :I
Argh, wish I had read properly as well
