Its super pretty but fricken i dont know how well of a case it accually is. The reviews are bad thats why i came here thanks
http://pcpartpicker.com/p/2SVkE
It has a dust filter for the PSU. It comes with 3 pre-installed fans,and there are cable management options (not sure how good it is). Overall it seems like a decent case, however $50 seems steep for it.
Fractal Design Core: http://pcpartpicker.com/part/fractal-design-case-fdcacore1000usb3bl
Rosewill: http://pcpartpicker.com/part/rosewill-case-linem
Check out pcpartpicker's case page with the filters I've selected:
http://pcpartpicker.com/parts/case/#t=5,7,6&u=1&f=7&sort=a8
I dont mind spending 50 bucks on this thing the cases you mentioned are ugly and i want something bueatifal thanks for your help, im sticking with this case and accually its only 40 bucks on amazon pc part picker is a shit website. and doesnt see that
I don't know if you bought that case already but I picked up a rosewill to get my setup out of the old dell box for some air and while at first I was satisfied when you compare it to other cases the lack of quality really shows. Some things are really flimsy side panels, plastic tabs that feel like they are always about to break, they are just not worth it.
When I chose my corsair for my totally new build it was solid as a rock and I couldn't find a damn thing wrong with it. And in hindsight if I had noticed the fractal case Betax64 posted I would have taken that over the Rosewill.
