Cynogenmod update 12.1 help
how do i start/dial a call?. i dial a number not in my contacts cant figure out how to dial it. have oneplus, it wants me to text or add it as a contact first. thanks
There should be a button, just above your "home" button that is a blue? Circle with some squares in it...
If you tap that it should bring up a dial screen... At least that's how it works on mine anyway...
tap home button
you should see a phone icon
tap it ofc
then tap the icon that has a bunch of arrows pointing downwards.
ps. I have one as well
Thanks for the help @Dr_Shade @MrChumps. Here is a screen shot.
It is invisible under the 0 for some reason.
Do you know how to make the Google search bar transparent?
Is it because your using a skin? As you said, the dial button should be under the 0, maybe try without a theme.
Im not sure what launcher oneplus uses. But in nova launcher (very good stock like launcher) you can select the ICS search bar which is transparent.
With google launcher, theres no option to change it.
I'm don't know about making the google bar transparent, but there's definitely an option to remove it from your homescreen altogether.
Ahhh... Sorry... Didn't realise to you meant the actual go button... I was a bit derby last night...
It used to be transparent in this theme before the update.
