Cyanogenmod help? (Please help!)
I have cyanogenmod (The newest version) and it just asked me to update. I have 0 idea what to do because this is my first time with it.
The menu says Cyanogenmod Simple Recovery <3e>
CM_M7-userdebug 4.4.4 KTU84P InstallerXNPQ29S
Swipe up/down to change selections:
 Swipe right to select, or left to go back.
Option:
Reboot system now
apply update
wipe data/factory reset
wipe cache partition
Wipe media
______
When I click the apply up date it asks to go from ADB or internal storage but Idk what to do... please help!
I have the HTC one m7
What phone do you have?
HTC one m7
guys I really need help on this... Like I am having an anxiety attack because this is my only phone and I can't get into the phone because its stuck on that page... I can't download files on it because my computer doesn't recognize it.... please help ;-;
sorry I am being impatient but bump... I really need help. I didn't exactly buy this phone myself so the buyer will be mad at me..... please help?
Try reflashing the stock images maybe, then put cyanogen back on it?
And if you downloaded an updated version of the ROM already, do "Apply update" from internal storage, then navigate to the .zip file it downloaded.
If all else fails, download the CyanogenMod Installer from get.cm and run through the process
Before you download the installer, first try to factory data reset, and then wipe the dalvik cache.
I can't download an updated version.... It won't let me because my cpmputer doesn't recognize it and if cyanogenmod automatically downloaded something I cant find it
Did that, it just goes back to the cyanogenmod recovery
Cyanogen downloaded the updated version. Its probably in your downloads folder, or CM or something like that. That's the file.you need.
Try downloading it on an other computer.
Well i already wiped it so it isn't in there anymore.... I am screwed
That wouldn't work because Usb debugging probably isn't on
boot into the bootloader and flash stock onto it via ADB/fastboot
+1, if you don't know what youre doing, start with stock and take it slow. That's how I learned.
Don't worry guys... i got it now... Had to reset everything. Oh well. Next time it wants to update what do i do? Do I have to download something from my computer or will cyanogenmod auto download it then i just have to go into the install and search for it in a folder?
try the auto installer from get.cm
