CyanogenMod Help - Galaxy S3
Hi Guys,
So... I am in aus, 2 years ago I was STUPID enough to buy a Galaxy S3 on a plan from Telstra... I have now replaced it with a OnePlus. As this is using a Telstra/Samsung Copy of Android and such companies are a pain when it comes to updates i am still running Android 4.2. I i want to install CyanogenMod on it so i A have a spare and B have i phone i can develop shit on... so here come this tricky part.
CyanogenMod has a list of varing GT-I9300 series Galaxy S3 devices and mine is not on there... mine being the GT-I9300T, and I cannot seem to Find a straight answer on what makes the GT-I9300T Different if it is Different.
So my question(s) is this, wat is special bout the model T, and wat set of instuctions do i follow install CyanogenMod on it?
Regards, The Fat Hacker
EDIT: to clarify mine S3 is the NON LTE version
I had a quick look and found this thread on XDA
Check out post #8.
I'd think that flashing it with the regular GT-9300 rom SHOULD be fine.... But make sure to backup the current one before going ahead with that.
I agree, it should be fine. I have installed versions of cmod for htc variants which are not listed in the compatible list from cmod and have never had an issue, back up though! Â
