Looking for a place to get a custom XXL mouse pad (~36" in length). Wasn't able to find one online. If anyone knows of a good one please post it.
Thanks.
Thanks.
http://www.amazon.com/Corsair-Vengeance-Extended-Gaming-CH-9000046-WW/dp/B00FK1E41U/ref=sr_1_2?s=pc&ie=UTF8&qid=1407449259&sr=1-2&keywords=long+mouse+pad
http://www.amazon.com/Perixx-DX-1000XXL-Gaming-Mouse-Pad/dp/B00EG7WB8C/ref=sr_1_1?s=pc&ie=UTF8&qid=1407449259&sr=1-1&keywords=long+mouse+pad
http://www.amazon.com/Extended-Gaming-Mouse-Mat-Pad/dp/B00J2EF4K6/ref=sr_1_4?s=pc&ie=UTF8&qid=1407449259&sr=1-4&keywords=long+mouse+pad
Just a few, think razer has one too
is this like reverse psychology spam?
I'm aware of these ones, I'll probably end up getting one if I can't get a custom one. Was looking for a company that could do prints on a pad.
Wow didn't even see the custom part lol fail, but yea in terms of a high quality custom mouse pad, I really couldn't tell ya. Keep searching :)
Thanks anyway.
http://www.inkedplaymats.com/products/custom-oversize-playmat
Thank you very much. I'll give this a try later.
Do this:
- find a local glass worker
- ask for frosted glass (sanding or acid etching, it has to be really smooth like the icemat) of your desired dimensions (5mm thick), and ask if he can smooth out the edges
- use black paint spray on the bottom
- when the paint is dry, get some rubber feet and stick them on the bottom
I've had this kind of a mousepad for 10 years and its still as good as new. You should also get some teflon legs for your mouse for the smoothest motion. Its cheap and it never wears out.
I can always count on you to cheer me up ... thanks dude
