so, because I have little money (side effect of being a teen with no job) and want to try out water cooling I plan to build a waterblock out of a generic hyper 212 eve style cpu cooler, cheap hose from ace , sheets of copper, jb wield, solder, various fittings, a huge ass fan, a car radiator from a local junkyard,waterpumps for ponds, and a fishtank as a resivour.
So far ive got
a fishtank , cpu cooler , jb wield , solder and iron ,waterpumps (are weak so will buy more and put in series) , and some cauk, tap water for coolant
I was quoted $20 for the radiator and ill spend $10 on hoses the copper sheets are $20 and i will use 1 and i estimate $20 for fittings
so is there any advice from you guys? Is there anything CHEAP I can add to this to make it better? Has anyone else here done this? keep in mind I REFUSE IN ANY WAY to buy a new radiator, or coolant, unless one of you wants to sell a kit for a $25 amazon giftcard which you obviously wont, and that i only get bits of cash at a time so this will take months to build
no, I am not going to buy bullshit watercooling closed loops that have no decent amount of cooling nor will i ever be able to afford to buy a custom rig, I would much rather follow my current plan
This can't end well. Conductive coolant, mixing metals, etc. I would love to see this try to cool a computer from the pentium days. It would be an entertaining video, but please don't do this to perfectly good hardware.
I would like to see this. Win or fail. See if you can find a Jet turbine and use that as a pump instead. Also just shoot liquid Nitrogen through the tubes, also get mini sharks and put them in the fishtank. I also don't think Coolant is that expensive if you have a PC store near you or can get on Amazon, it shouldn't be too expensive and can save you a couple of degrees.
good luck on ur waterblock, im highly confident within a few weeks you'll have corrosion and deterioration of the entire block. That's if you don't leak out and burn your sockets down. You're a teen and have no job...don't even think about building a watercooling setup aside from closed loop. The swiftech h220 (which i like) won't perform much better compared to an h100i. If you want to do watercooling you want treated copper done in facilities not made in a tool shed. Number 1 rule on a good computer is to not go cheap because you will ALWAYS get fucked when you go cheap. If you want it done right, either look for an EK or XSPC starter kit which costs around $160-180 for a drive bay kit. These are going to be the best for the value without sacrificing quality.
