Hi guy,
i am doing my very first build and i just need some advice please
what custom water loop kit do people recommend?
Thank you.
Hi guy,
Thank you.
Alphacool do some nice compact ones with bay reservoirs, although they use DDC pumps, which are quite loud and annoying without proper speed control.
XSPC have some really good kits, with pretty much a radiator to fit any size available.
EK are now starting to do some, except they tend to be a little more expensive than the XSPC and Alphacool kits.
Thank you I don't mind on the price i just want my first build to look nice
i will check them all out, are they easy to install i have watched a few
YT video it looks pritty simple
The EK kits are really nice. They are a good jumping off point for water cooling.
Just remember to take your time. Be very methodical and you'll end up with a slick looking loop. Please post pics when you're done! I love seeing what others in the PC community are doing.
Yeah i sure will that not a problem, and i will take my time this pc will be my pride and joy :)
its my very first build just hope everything go's well :)
