wait why are you going with the case that is wider and longer if you are having issues with desk space?
I saying that his case is wider and longer....
Its girthier, some might say. Its fine, some people can't handle it.
>Space issue
>goes with wider, longer case
wut
Learn something new everyday.... Urban Dictionary gives the most appropriate examples.
well what ever you choose every case that has been listed on this thread supports ATX mobos
Well this gave me a laugh.
Every case besides mine?.... Um.... did you even care to check?
And agian, I was referencing CloudScorpions' case saying that his is longer and wider.
You're making me blush bro.
If you can only handle a modestly sized one, you really don't have all that much room to move, can go for a micro-ATX tower, can't go for the slim micro-ATX becaues they only accept low profile cards. Unfortunately no one makes a decent mini-itx AM3+ board, so the mini-itx cases aren't really an option for you.
If you can't do anything else, get the case I recommended and brace the damn thing to the ceiling.
EDIT: for anyone confused, I've been making dick jokes.
I shall sincerily consider your alternative if the situation arises that leaves me with no other option.
its inplyed every one except yours and yes I did check
