Custom R9 290 Tri X
Hello.
I want to paint my R9 290 TriX, i see on this video https://www.youtube.com/watch?v=c0yYrcf-0jY
that he use Plati Dip, if i do that i will broke the warranty?
I want this:
https://teksyndicate.com/comment/1742244
Thanks!!
i doubt you'll void warranty. (unless they are clear that you can't) most of them won't care about plastic. (unless you are against some draconian Chinese company)
Hello.
So i can use Plasti Dip, its a good paint (quality)?, if the grapphic card broke for example in 3 months i can remove it?
Thanks!
the only thing you should be concerned is melting temp of your paint (plasti dip is 300'C as i remember). Your gpu can go as high as lets say 90'C in bad conditions.
If you won't leave trace for manufacturer you can do anything to it, and still have it rma. (though most manufacturers don't really care for painting/taking off plastic covers.)
still be careful it doesn't get into fans or radiator, or pcb.
You know what color is this? https://teksyndicate.com/comment/1742244
I think its matte black right?
Thanks!
look more metallic (i suspect he simply used common black spray), but then again we have only 1 picture... i'd be better to ask that person.
Ok, thanks for your help!
Best regards!!
