Custom R9 290 or GTX 780?
Hey guys, Im back again.
After asking which custom R9 290 to go with....I am still not sure if I want to go with the AMD route.
I need your help to help me choose between R9 290 or GTX 780.
Does the 1 GB RAM give the AMD cards a slight advantage over the NVIDIA card?
Which card works for gaming and productivity?
Pricing is pretty much identical here in the U.K, so not really a issue.
I really need your advice.
Thanks guys.
What resolution? At higher resolutions the extra memory bus on the 290 theoretically gives it a performance boost, the extra vram could help a year or two down(or with mods sooner) the road right now the general feel is 3gb is enough. Just all depends on what you are wanting to do.
