Hi,
I've recently built my own desktop PC but it tends to freeze
around 20 minutes into games (such as MGS V TPP), but strangely running a simnple
NDS emulator will also cause the system to lock up after a little while.
This has also happened while transferring Steam from HDD to SSD (a little over 30GB at the moment).
Here is a list of my hardware.
CPU AMD fx 9590 black edition
DDR3 RAM (4x 4GB) G.Skill Ripjaws X (F3-12800CL9Q-16GBXL)
GPU msi geforce gtx 970 gaming 4G
Motherboard msi 970 gaming
HDD 2TB Seagate Desktop HDD (ST2000DM001)
SSD 256GB Crucial MX100
PSU 550W Seasonic S12G
OS Windows 10 x64
What happens during a freeze:
90% of the freezes/hangs will simply lock up the system. Nothing will react
and the NumLk button on my keyboard will also no longer power the NumLk LED.
This happens while doing anything that requires a little more juice. (Playing games with
heavier graphics, but also using something as light as a Nintendo emulator. Hosting a Mincraft
server [wich requires a fair amount of CPU usage] also causes such freezes.)
Rarely, under the sane circumstances, the PC will also freeze for a couple seconds,
then turn off entirely (crash I guess).
Things I've tried: (began with windows 8.1 pro)
- Check for driver updates
Run different benchmarks and a memtest to find potentially faulty hardware
(rather high score in FurMark and no issues detected using others)Check system for corruption and other issues using the command propmt
(SFC /scannow) (DISM /online /cleanup-image /scanhealth)connected the sata cables to different ports and moved the GPU into another slot
wiping the PC and clean-installing windows 10
repeating the above in windows 10, in wich the issue wasn't resolved
The rather frustating hangs still persist and I've run out of ideas.
I think that is all I have to say,
I tip my hat to any brave souls who would help me resolve the issue.
Thank you in advance,
Josh
