Custom pc from computerplanet
http://www.computerplanet.co.uk/custom/amd-a-series/step1.html
ive also upgraded more stuff .
why not build one yourself? you can get so much more for the price you are paying on there.
You may want to double check that..mainly because you did not even select a CPU..
 Buddy, if anything, go with this build, it's as good as it gets for budget UK build that I can find.
AMD A10-5800K 3.8GHz FM2 4MB 100W Black Edition £95.26
Gigabyte F2A75M-D3H AMD FM2 A75 DDR3 mATX £55.84
Seagate 1TB Barracuda SATA 6Gb/s 64MB 7200RPM Hard Drive £54.99
Patriot Memory 8GB (2 x 4GB) DDR3 1866MHz Viper 3 Black Mamba DIMM CL9 £36.72
Antec Earthwatts 380W ATX 12V 80Plus £36.49
Gigabyte IF233 Miditower USB 3.0 £30.99
Total: £300.19
Parts priced used Dabs.co.uk
