Custom mini itx case for watercooling (Project Lan Syndicate)
my current custom case (danger den lan 450 extended) only has room for 1 240 rad. I'm running a 4790k and a titan z. had to run the fans higher rpm than I would like to keep the temps down.
so I'm having this case made. its a bout 13" long by 13" tall by 13" wide. and can hold 2 240 rads 2 ssd,s and a fan controller :)
<img src="/uploads/default/original/3X/0/9/097cdf899913709a99334833dde29d2cabc823b3.PNG" width="309" height="550"
It should arrive in about 3 weeks :)
case just arrived :)
Nice! I like the chamber separation. What will go in the space between the rads, the SSDs? Will you have the GPU, CPU, and both rads on a single loop? Would love to see a build log!
just curious - who or what made this case? :D
thanks! maybe the res pump combo. there is not going to be much room though 1 80 mm thick and 1 60mm thick rad plus fans suck up a lot of room. ssd'd are mounted abouve the 5.25 bay (2 ssd's). and yes I'm thinking one loop at the moment. and I will be doing a build log :)
I got protocase to make it for me :)
Always a fan of custom pieces... Would love to see an update with a rig inside.
Excellent. Yeah, might be tight with the res/pump, but having most of the waterworks in the one chamber would make for a really clean build. Looking forward to seeing what you do with it!
A beaut.
what kind of controllers are you looking to use?
Beauty of a cube, but I'd love to see the built system as well.
thanks man! I just ordered FC5 v3 lamptron
thanks man!
ill be posting the build log here
Looking forward to seeing what you do with it.
i am a fan of cubes, nice man
This is what im thinking for the for the front :)
most of the parts came in!!
case rev 2 came in!!!
Nice, cubes are where it is at.
got a new mid plate with a hole in it. the mounting hardware screws were in the way with the last mid plate. should be fun to pipe LOL :P
