Hello! I am planning out a custom loop to put in the Corsair 380T.
My current specs. are as follows:
CPU Xeon E3-1230 v3
GPU Radeon HD 5570
Motherboard ASRock B85M-ITX
RAM 8GB Corsair LP Blue
Case Fractal Design Node 304
I am going to be upgrading my GPU to a GTX 970 and (I am considering upgrading my CPU to the 4790K and grabbing a Z97 motherboard) getting the 380T next month so that's about when all this is going to happen. The current list of parts I am planning on getting the following parts for my loop:
- Pump/Res: http://www.frozencpu.com/products/14981/ex-pmp-182/Alphacool_DC-LT_Ceramic_12V_DC_Pump_Plexi_Top_Reservoir_-Installed.html?tl=g30c107s152&id=j7rzrFmL
- 120mm Rad: http://www.frozencpu.com/products/4082/ex-rad-82/BlackIce_GT_Stealth_120_X-Flow_Radiator_-Black.html?tl=g30c95s159
- 240mm Rad: http://www.frozencpu.com/products/12702/ex-rad-227/MagicoolExtreme_Dual_120mm_Radiator_-SlimProfile_LC-RADI240.html?tl=g30c95s160#blank
- Coolant: http://www.frozencpu.com/products/24687/ex-liq-414/_EK_Ekoolant_EVO_Concentrate_100mL_-LimeGreen.html?tl=g30c337#blank
- Tubing: http://www.frozencpu.com/products/10491/ex-tub-651/Tygon_B-44-4X_38_ID_12_OD_-Non-PorousSmooth_Tubing.html?tl=g30c457
- GPU Block: http://www.frozencpu.com/products/16600/ex-blc-1179/EK_GeForce_670_GTX_VGA_Liquid_Cooling_Block_-AcetalNickel_CSQ_EK-FC670_GTX_-AcetalNickel_CSQ.html?tl=g30c311s1708
- CPU Block: http://www.frozencpu.com/products/16251/ex-blc-1131/EK_Supremacy_EVO_Universal_CPU_Liquid_Cooling_Block_-AcetalCSQ_EK-Supremacy_EVO_-AcetalOriginal_CSQ.html?tl=g30c325#blank
If you're wondering the EK 670 Full Cover blocks fit the GTX 970s with the stock PCB so that is what I will be using as that is all that is available for the 970 at the moment. I am going to be putting the 120mm in the back of the case and the 240 in the top right of the case(if you are looking at it from the front). This is my first time doing any watercooling so I would love to know if there are any better alternatives to the parts I have chosen.
Thanks!
-Boomerang
