Hmm. That is quite the next step up, especially from a VB point of view.
C# and VB in the .NET framework is built upon the concept of productivity and functionality. You gain tremendous amounts of stuff that works very easily with minimal work.
If you want to stick to that concept, I think your looking at rendering DirectX or even OpenGL windows with custom art work. .NET's drawing packages may be able to do a bit of what your after...
This sort of thing? Drawing libraries should work fine.
http://www.codeproject.com/Articles/17874/Custom-shaped-form-with-a-drop-down-in-C
c# and VB are mostly interchangeable. Just the syntax is a little different.
It's mainly to make the form look like Windows 8 even if it's on Windows 7. Square buttons instead of rounded edges and likewise with the main form window.
Right. I'll give you a little basic rundown here. And a possible solution.
Within your Operating Systems you have something known as a desktop environment. This is the part of the OS that deals with calling new "windows". In Windows OS if you make a call for a new form/application it puts it into one of these windows/contexts. The OS handles the borders, the style of standard fonts, the buttons you talk about, the menus, etc. If you made a program in something like Qt that ran on Windows, Mac and Linux the respective OS would style your border and controls of your form. So your program would look, feel and work exactly like a Mac OSX window. That dropdown tooltip menu in windows will naturally become that topbar menu in OSX.
So, there isn't really a way, that I'm aware of, to customise the standard form with say image as it isn't your program that deals with it.
I see two methods which are essentially the same thing. But only one that would suit you... possibly. If you go to the forms properties (assuming your in vb.net or c#.net in a Visual Studio based IDE), then there is a form border style property that you can change to borderless. This will get rid of the border entirely, including its functions. Changing the properties here is basically asking Windows for different form types.
Now you use the drawing libraries "System.Drawing" iirc, to layer squares into set positions that scale/move with form resize. Unless you make it static size, which is easier :D
If you want a blue border, you draw a blue rectangle 100% height and width of your form. Then draw a white/grey/imaged rectangle ontop that is always say, 10px in from left and right, 10px up from the bottom and 50px from the top. Simple math should be able to find it's size and how much to move its x & y position into place. Draw your logo to the top-left, program name in the middle. Then draw your buttons in their location, give them mouse-over, and mouse hold images and swap accordingly. Give the buttons their respective functions and voila, a blank, custom form. Your program will go onto the white or grey area as normal.
If you've done any web stuff with div tags that should make sense. Its really not that much to fake a static sized window. Dynamic windows just require good use of simple maths and functions. Making it polished would be a good simple project.
I looked on YouTube and found a demo for Custom UI so I might go the borderless route but I want a border to the rest of the window. Any ideas other than shifting things about?
