(A follow up from the previous thread, but things have changed a little.)
Hello all, I was wondering if I could get some advice on whether or not my storage plans for my graphic design rig made sense.
For some background, I specialise in typography, calligraphy, textures and creating print based products (stickers, prints, etc.). I don’t really do much video work if any, and I rarely work with RAW’s (Although if I start making more photo based textures that might become a thing). I use the Serif Affinity set of programs which unlike their Adobe counterparts do not use a scratch disk. I don’t have any plans to go with Adobe so this does not bother me and I don’t really use DaVinci enough to justify it. My current computer is a Lone L5 (it’s portable), with, an ASUS X570-I as the motherboard. It has two M.2 slots. The first slot has an ADATA XPG 8200 pro which serves as my boot drive and at the moment holds everything else. Besides that I can only get 7mm 2.5 drives to fit. I don’t have access to any more PCIE slots due to using a two slot GPU.
Now to get to the point, I’ve been looking into a larger capacity internal drive that I can use as a place to put relevant projects, assets and references. I’ve been trying to find a drive that is around 4TB and has power loss protection (PLP) due to the fact it will have active client work and my current products on it. I’ve been looking into U.2 drives due to the fact they have capacity, lower temperature, quite a few of them have PLP and to take advantage of that other M.2 slot via an adapter. One option I have been looking into is Micron’s 7300 models. There two that I’ve been considering. A 3.84TB Pro (read) model and a 3.2TB Max (write) model. They seem to have some level of PLP, but it seems to be for “In flight”, would that be enough?
Simple thing is, does this plan make sense.
Thanks for you time, I’m open for other ideas if anyone has any.
