my current build to buy is good by my standards, and will play a lot of games well, but i want to see what you guys can come up with.
currently:
FX-4100
Radeon HD 7770
4GB 1333 Ram
WD Blue 1TB
Cougar RX500 500w
Sentey Cobra Extreme division case
windows 7 64 bit
arctic silver 5
Asrock 970de3/u3s3
All shipped to my house for a total of $596.24
i'm willing to change anything but the motherboard, as it comes with an ide connector, and i won't need a disk drive much anyhow, just to install windows.
also if you make suggestions, try to find them on newegg first. I have been using newegg, as it's much easier to find the components and catalouge how much it will cost in total, at least for me.also when you are making one, factor in the cost of windows, as i have no other way to get it.
not for $600 total build as that would be a third of the money going to the processor, and assuming i want to limit bottlenecking, i should get a graphics card for around $200, and that woule leave me with $100 left, because windows is $100.
where have you saw the 965 outperform the fx-4100 because in all the benchmarks and game fps comparisons i've seem, with identical components otherwise,they got VERY similar fps, 1 fps max, and the fx runs on 30 watts less power, which is more efficient.
ide/sata converters are a minimum of $10 on newegg, where i will be buying the components.
also, and this is just me nitpicking you spelled they're wrong twice...
still, i will look into getting a psu with a single rail, as i have heard it typically is better.
The example is in a synthetic benchmark, where when actually being used in gaming, the fx matches the phenom II and still uses 30w less. As it has a newer core, and the fx (supposedly) is better at overclocking, which i hope to do. I will consider them both.
as for your spelling, again i'm a bit of a prick about spelling. Sorry.
$60 - $10 Promo code - $20 MIRc = $30! So you pay $50 for it and then wait for the MIRc, but essentially is a $30 price (assuming you fill out the rebate info and get the $ from it).
You can always click on the PCPartPicker link in my original post and see where the part is located. Then just click on the part listed and your good to go :)
OK. Use Ubuntu (or other type of linux) until he gets enough money to buy windows. Or he could downgrade to the radeon 7770. Or torrent OS, which I do not endorse.
I included a 7850 in my build(s), so that would be better than the 7770 that you suggest. I also don't endorse torrenting the OS, so I included it into both of my builds, so everything is legit.
the fx 4100, is terrible it's out performed by an i3 dual core. The phenom II X4 965 BE is cheaper, better and has 4 physical cores and overclocks pretty damn well. My little brother has the fx 4100, i have the 965 be and we have the same graphics cards, yet i am getting better performance. Bulldozer is bullcrap, at least go with piledriver if you want to get FX
