Crysis 3 Three-Way Eyefinity 1080P build?
This is my current build. What do you guys think about it running what the title says? I call her Neferro.
http://pcpartpicker.com/user/alphaneus/saved/#savedbuild_316803
You may be able to do it on low settings
Yeah, that's not quite enough power for higher settings.
Suggestions, budget would be about maybe...1-200 more.
To run crysis in eyefinity on reasonable settings, you need no less than a 7970.
So you think this
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161412
for only $20 more would be capable?
yep.
Thanks! :D Helpfulness appreciated. The rest of my build look sound?
the CPU is more than likely to cause a bottleneck, whats your max budget?
http://pcpartpicker.com/p/MIpn here is one for about $1600 after rebates, with some combo deals, the 3 monitors included, CrossfireX with 2 7950's. and ALL free shipping. Happy Overclocking! I also went with the dark knight. Logan said that is near on par with the H100. Your welcome.
that's a little pricey for me. I just threw an 8350 in instead of the phenom ii x4.
I feel like you may want to go with a four gig card, at least. What are the monitor resolutions?
so max of about 1200?
Yup. And I want to go with the HIS IceQ X2 g card. It's great at OC. As well as the HAF 912 case. I think i've got my build figured out. I just watched the Review of the Diamond 7970. Crysis at 1080p across 3 monitors got 20 fps, and i won't mind turning down some settings to get it running smooth. Thanks for your help guys!
spent money in weird ass places.
