My $600 "only buy what's on sale" rig should run it well. I might upgrade to a 7000 series GPU, but my 6950 2GB has been handling everything fine so far. We shall see.
I'll wait til 2014 to buy the game so I can get a patched/less buggy game, most likely catch it on a Steam sale for $4.99 with all DLC included by that time (Maximum Edition will be added to Steam inevitably, like Crysis 2) and by 2014 I'll also have better hardware to max it out (GTX 880?) on a reasonably priced 4K display that should also be available by 2014. Remember, patience is a virtue.
I cant wait for the action and graphical wonder that is crysis 3 once pre orders go down I will jump right on it as I finally want a game that makes me have to trun down some of my settings to run at 60 fps
I believe my upcoming i5-3570, 16GB DDR3 RAM, GTX 660 (or 760 Ti?) system, loaded with Intel SSDs will be able to handle Crysis 3 on high settings. Mature drivers & optimized game engine performance will sure make the game less heavier to run than it is now.
Keep calm and wait for the game to come out :) I was blown away by how well my GTX 295 ran through Crysis 2 and Metro 2033 in DX9.
I should be fine with my i7 2600K @4.6Ghz, 8GB of ram, and two 3GB GTX 580s in SLI. Although, I am going to be upgrading to 2560x1440 soon, so that might drop the framerate just a bit. The fact that the high end requirements asks for 8GB of ram makes me wonder if I should upgrade to 16GB too, but I really doubt I'd need to.
I'd like to point out the hilarity of the high-performance spec recommendations. To run this on max you'll need an i7-2600K ($320) or a FX4170 ($120, it said 4150 but that doesn't seem to exist). Kinda give a hint that these are somewhat random, I can't imagine why they would think an i5 2500k couldn't handle this but a FX4170 could. Though to be honest, I'd be willing to bet an FX4170 will be able to handle the game on max settings, I don't recall Crysis being a CPU whore, just a GPU whore.
