In my upcoming (and first) build im going to get a 7970 Direct CU2 top, which is a tripple slot GPU and as upgrade later on i want to buy a second one for a crossfire setup. im going to get the AsRock Extreme4 Z77 with a 3750k.
would this work on this MOBO (Bus speed wise and cooling wise) or should i just get the 7970 from MSI? and also, would an AX850 80+ gold be enough to power the 2 cards?
no, not unless your doing a burn-in, and even then, it's not that bad. I've actually been near a righ using one during a burn-in, and their not that noisy
Crossfire has really bad driver support. Just doesnt work very well. PSU need probably about 650w or 750w if you plan on OCing alot. A 650W 80 plus gold should probably work for crossfire setup no problem.
that is true, for xfire, at least, but he's starting with a single card. and 80-plus really don't mean much, as long as it's at least bronze. getting a platnium vs a broze really make no difference.... and for xfire, it's good to have some room for periphrials and other stuff that draws power
ummm, the thread u linked me to basically says that you save less than $20/year at 8 hrs/day. so, unless it's a server, there's no point to paying more for anything above bronze. that said, if you find a higher rated one at the same or lower price, go ahead and get it.
